Pocket GPS World :: View topic - USB Power Adapter in Car
JLee
PostPosted: Mon Jul 12, 2010 2:22 pm    Post subject: USB Power Adapter in Car Reply with quote
Since the XL Live IQ Routes has a USB power connection does it follow that it's safe to connect it to standard USB car charger rather than the one that came with the unit?
I ask because the one that came with it is wired behind the dash in my car but I ocasionally want to take my unit and use it in another vehicle so would like to use the USB car charger I use with my Blackberry.
I presume that USB powered devices all use the same power rating?
MrT
PostPosted: Mon Jul 12, 2010 2:43 pm    Post subject: Reply with quote
USB chargers all have the same voltage of 5 volts however they do vary in the power they can output. The worst that is likely to happen is that they do not charge the TT if the power rating is too low. The car chargers I have from TomTom vary between 1.2A & 2A.
Drivelux
PostPosted: Mon Jul 12, 2010 3:15 pm    Post subject: Reply with quote
No issues at all, as long as the charge can supply 1.2A then it will be enough to power AND charge your device.
PostPosted: Mon Jul 12, 2010 3:51 pm    Post subject: Reply with quote
The only other thing to watch for is the angle of the USB plug.
TomTom themselves have altered this on different models more than once, so if you pick up the wrong charger, the plug might not physically fit into the device (or it's mount).
(Been there, done that! Mad )
JoolsTwo
PostPosted: Mon Jul 12, 2010 4:35 pm    Post subject: Reply with quote
you could always get a tomtom compatible car charger from ebay, I'm sure you could get one from china really cheap.
TomTom ONE Series 30 (v8) & TMC traffic
App 8.010, UK & ROI Map v860.3126, TT Home 2.7.6.2056
MARViN2003
PostPosted: Mon Jul 12, 2010 5:05 pm    Post subject: Reply with quote
Watch out for USB adapters supplying too much power. I popped the charging circuit on my 520 by using one. I would probably suggest getting an extra tomtom car charger and mount.
PostPosted: Mon Jul 12, 2010 5:35 pm    Post subject: Reply with quote
So long as the adapter and device adheres to the USB spec then that should not happen. I've never had an issue and use whatever miniUSB charger is at hand!
JLee
PostPosted: Wed Jul 14, 2010 1:39 pm    Post subject: Reply with quote
Thanks for the advice everyone. I used a generic car charger with USB input and a standard USB cable and it worked a treat. It's refreshing to see a device use such an industry standard charging system meaning you don't have to pay the earth for a second charger.
PostPosted: Wed Jul 14, 2010 7:53 pm    Post subject: Reply with quote
As Darren mentioned though, check the current rating on the cigarette lighter adapter.
If you use a cheap USB supply, it's uncertain how much power it will be capable of supplying as a "computer standard" USB device is only allowed to request a maximum of 500mA from a USB supply.
In this respect, most sat-navs are non standard as they can draw a lot more than that to charge their batteries which is why they use higher specification chargers.
22.051 (01 May 24)
