Pocket GPS World :: View topic - NEW BATTERY FOR TOM TOM GO 500
winston777
PostPosted: Mon Jan 11, 2010 10:18 pm    Post subject: NEW BATTERY FOR TOM TOM GO 500 Reply with quote
Anyone know how to fit a new battery to a Tom Tom go 500?
Unit will have to be opened up,but there are no obvious means to do this.
PostPosted: Mon Jan 11, 2010 10:47 pm    Post subject: Reply with quote
Pop the screen surround off the device this is the silver part it can be prized away from the rear shell of the device using no more than thumb nails, once removed you gain access to the four torx screws to release the unit from the case, note torx bits that fit in to a screw driver won't be long enough you will need fairly long reach torx drivers for this.
I can take a unit to bits and post up a guide on how to do it if thats any use but it won't be tonight as my Torx bits don't fit! (I just tried and failed) - Mike
winston777
PostPosted: Mon Jan 11, 2010 11:47 pm    Post subject: Reply with quote
Thanks for the info.A guide would be a great help.
Got a set of long - reach torxs, so o.k. with that.
Antoeknee
PostPosted: Tue Jan 12, 2010 10:48 am    Post subject: Reply with quote
Sorry to jump in here but there is some images etc. if you scroll down this page. Might save you a bit of work Mike.
http://getsatisfaction.com/tomtom/topics/how_do_i_get_battery_replaced_in_a_tomtom_go_700_is_usa_or_get_tomtom_support_to_improve
PostPosted: Tue Jan 12, 2010 11:59 am    Post subject: Reply with quote
On the Go500, I think you can push the mounting latch on the bottom (in the circular bit) towards the front of the unit and that helps to push the bezel off.
Antoeknee
PostPosted: Tue Jan 12, 2010 2:25 pm    Post subject: Reply with quote
Thats correct Andy
winston777
PostPosted: Tue Jan 12, 2010 3:14 pm    Post subject: Reply with quote
Thanks for all the info.New battery on order from Ebay.
