Pocket GPS World :: View topic - CP8 HD2 Unable to find route type or set arrival time option
Rik1280
PostPosted: Sat Apr 03, 2010 1:39 pm    Post subject: CP8 HD2 Unable to find route type or set arrival time option Reply with quote
Hi, I'm running CP8 version 8.0.0.659 on my HD2, the manual shows the following options but when I select options neither Routing type or set arrival time are there.
The options I have are: 2D/safety view/Itinery/volume/
mode of travel/landscape/rotate map/Compass so I'm unable to choose betweem fastest/shortest/economic routes.
Please help.
Select Routing Type
CoPilot Live provides the facility to adjust the routing depending on the nature of journey
To do this select the Options menu and the Routing Type.
Choose your preferred routing type, the options are:
Quickest
Shortest
Avoid Expressways
Economic
Please note that the CoPilot Live default setting is Economic.
A picklist box allows you to choose from three options relating to toll roads. These are as follows:
Allow Tolls
Avoid Tolls If Possible
Always Avoid Tolls
Set Arrival Time
In this feature you can set a time for when you would like to complete your journey. CoPilot Live will then generate an Estimated Time of Arrival (ETA) based up on the route.
Select Options, then choose Arrival time.
Set your time of arrival: Hour, Minutes in increments of five minutes) and AM or PM
Once jounery time is selected, press OK.
23.043 (17 Apr 25)
