Pocket GPS World :: View topic - MIO168 charge voltage?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds
lencuff
PostPosted: Mon Aug 31, 2009 9:16 pm    Post subject: MIO168 charge voltage? Reply with quote
Getting so fed up now with failed connectors that I have the wiring for the socket so thinking of making a lead to charge it separately via a decent connector. Anyone know the charge voltage needed? I'm guessing 5V but don't want to mess it up and blow it!!
Cheers,
Len
PostPosted: Mon Aug 31, 2009 9:25 pm    Post subject: Reply with quote
If its a Mini USB connector which I think the device has the voltage will be 5V, you need to supply at least 500mA to the device from the regulator circuit although a VReg with 1000mA would be a better solution - Mike
lencuff
PostPosted: Mon Aug 31, 2009 9:33 pm    Post subject: Reply with quote
It's the awful multipin connector MIO fitted to this device. 22 pin but I can easily fit an external socket. Thought it would be 5V but just wanted to make sure!
Cheers,
Len
Pocketgps
PostPosted: Tue Sep 01, 2009 12:51 am    Post subject: Reply with quote
I have the Medion charging base for the Medion MD95000 (Mio 168 clone).
The mains power supply unit says:
Switching Power Supply
Ouput 5v - 1A max
Just to confirm that the Medion MD95000 is the same unit have a look at my web page HERE (opens in a new window).
PostPosted: Tue Sep 01, 2009 9:16 am    Post subject: Reply with quote
My 168 charger also says 5v 1A Very Happy
robertn
PostPosted: Fri Dec 11, 2009 12:16 am    Post subject: Reply with quote
A while back I had the same problem with my 168. I found an internet page that had photos of a couple of solder points, behind the 22 pin connector, that are good for the 5V input point. They are impossible to miss - the size of a small aircraft carrier compared to the pads the 22pin connector is soldered to.
If I can find the info I'll post it here.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds All times are GMT + 1 Hour
21.021 (01 Feb 23)
