Pocket GPS World :: View topic - File to copy across re speed camera warning sounds
peasemore
PostPosted: Tue Nov 24, 2009 9:41 am    Post subject: File to copy across re speed camera warning sounds Reply with quote
Having just got my TT back from Tom Tom I see that no speed cameras have sounds at moment; which is back up file that contains this data to save having to do each one?
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
PostPosted: Tue Nov 24, 2009 10:03 am    Post subject: Reply with quote
For PocketGPS cams? mapsettings.cfg in your map folder. But a backup will only work if the map version hasn't changed between backup and restore.
If the map has changed then it 'might' work. If you get issues, just delete the file and it will be re-created automatically.
peasemore
PostPosted: Tue Nov 24, 2009 3:37 pm    Post subject: what file Reply with quote
Thanks for that Darren; just realised posted in wrong lounge/section. Rolling Eyes
Same map as before so should be OK. Razz
Gel
