Pocket GPS World :: View topic - Navigon Route Instructions
mag01
PostPosted: Fri May 14, 2004 10:50 am    Post subject: Navigon Route Instructions Reply with quote
Is there a way in the Navigon software to display route instructions once a route has been calculated Question I would like to be able to see an overview of the route to see what roads have been chosen. The only way I can see to do this is to scroll around in the map display...
Mark.
Kirk
PostPosted: Sat May 15, 2004 12:57 am    Post subject: Reply with quote
Yes you can do this by going into the 'route planning' menu. You need to enter 2 or more destinations then click 'calculate route', then 'display on map' It calculates your route and you can zoom in to see which route it will take you. You can also do this without the unit attached to the antenna as it now knows where it is and where it is going!
You can also click 'start simulation' and it takes you there in real time also without antenna attached!
A few other things:
When navigating, touch screen and you get an arrow instead of map> you can also repeat last annoucement by clicking on the speaker icon.
Touch the distance icon and you can switch to:Duration:Arrival:Distance
You also have a night map by touching the sun icon.
There are a few other things you can do like blocking roads etc
22.051 (01 May 24)
