Pocket GPS World :: View topic - Updating Maps and POIs (740 Go)
kenwilk240
PostPosted: Tue Mar 29, 2011 7:27 pm    Post subject: Updating Maps and POIs (740 Go) Reply with quote
If the maps are updated on a 740 are the POIs overwritten. Reason I ask is that I would like to convert my favourites from the mapsettings.cfg file (I've had some issues on my device and I've had to reset mapsettings.cfg) to become POIs but don't want to do that if POIs get overwritten by a map update.
PostPosted: Tue Mar 29, 2011 7:35 pm    Post subject: Reply with quote
Custom POI files shouldn't get wiped out during a map update but as the process involves the use of TomTom Home I would recommend you take a backup of the ov2 files from your map folder prior to the update.
If the update works as intended then don't worry, if for some reason it goes wrong copy the ov2 files to the new map folder and you will have all your custom POI files intact - Mike
