Pocket GPS World :: View topic - Post code search is different on my new maps.
Burstner
PostPosted: Tue Sep 01, 2009 4:15 pm    Post subject: Post code search is different on my new maps. Reply with quote
I have recently updated from an old Western Europe map to Western andCentral Europe v 830.2307. This was via a download .The post code search is now not the same. I tap in the full code, which then appears on the top line, but only the first part of the code appears underneath that and I then have to scroll down all the street options to select the one I want. Is this the norm now, or can I do something to get the search as it was before? Please answer as simply as you can and, if possible, please walk me through it if there is a solution. Oh, and by the way I think I have a problem with my card reader so can't do anything which might involve that.Thanks.
Daggers
PostPosted: Tue Sep 01, 2009 4:55 pm    Post subject: Reply with quote
Sounds like you don't have the postcode data with your new map. Can you check and see whether there is a folder called "zip" on your TT, and whether it contains any files.
If not, you can copy the folder/files across from the Explorer backup you made before you updated the map (You did, didn't you?)
Garmin DriveSmart 50 LMT-D
LesMiserable
PostPosted: Sat Sep 05, 2009 2:43 pm    Post subject: Reply with quote
Here is the postcode file from the TT website
http://www.tomtom.com/updates/zipcodes/map7/wezipcodes715.zip
TT 500
Map: V855.2931UK & Ireland
Version 7.903(9183/081025) OS:2344
GPS v1.21 Boot 5.5022
TT Home v 2.7.6.2056
PostPosted: Sat Sep 05, 2009 3:20 pm    Post subject: Reply with quote
Go to "Oldboy's" web site by clicking Here where you will find a much newer postcode file set than that currently available from the TomTom download, these files will be better matched to your v8xx map - Mike
Burstner
PostPosted: Sat Sep 05, 2009 4:00 pm    Post subject: Reply with quote
Thanks a million, all of you!.very grateful.
22.051 (01 May 24)
