Pocket GPS World :: View topic - dnx7240bt low warning volume
martyn17
PostPosted: Sat Jul 04, 2009 9:16 pm    Post subject: dnx7240bt low warning volume Reply with quote
first of all i am sorry if this subject has been on before, but as i am a newbee and could not find any ref to my new head unit in a serch
first - the download went well and i found the instructions easy to follow -- thanks
my problem is that the warning sound is very quiet
is there an easy fix for this
martyn
PostPosted: Sat Jul 04, 2009 10:24 pm    Post subject: Reply with quote
(Moved to appropriate forum)
Is this the built-in beeps? If so, unless Kenwood have a configuration option that allows you to change that then No.
We supply the location data only, the alerts are a function of the unit.
martyn17
PostPosted: Tue Jul 07, 2009 7:32 am    Post subject: kenwood says Reply with quote
thanks for repley
below is the reply from kenwood which also contains ref to the disk error i have spotted when browsing the forum, hope it is of some help to anyone with the dnx7240bt
Yes it does say ‘Disc Error’ – because it does not detect it like a normal CD or DVD.
Under the navigation set-up part of the menu, you can adjust the nav guidance volume level, this should also adjust the warning tones for the speed cameras.
This level can also be adjusted using the main volume control whilst receiving a voice command from navigation
martyn
