Pocket GPS World :: View topic - help me transfer my satmap routes to memory map on my pc
howard40uk
PostPosted: Tue May 26, 2009 10:52 pm    Post subject: help me transfer my satmap routes to memory map on my pc Reply with quote
i have the 50 maps on my satmap and memory map on my pc is there anyway i can trasnsfer my satmap maps to memory map so i can print my routes out .can u alsp transfer my convert routes from memory map so the can go on my satnav
thanks
nonoftheabove
PostPosted: Wed May 27, 2009 7:46 am    Post subject: Reply with quote
open Memory Map for starters.
click OVERLAY on the top banner header.
select import.
( note folder where files are stored ) and select folder and file required
Note file type required and highlight that option
So we have Walk.gpx [for example]
select this and bingo it should be present and showing on the screen superinmposed on the map ; from there one can then look at the profile etc.
hope that helps.
howard40uk
PostPosted: Wed May 27, 2009 10:05 am    Post subject: Reply with quote
Hi thanks for help . But also if i plan a route on memory map can u transfer the track to my satmap not sure if this is possible .cheers
nonoftheabove
PostPosted: Wed May 27, 2009 10:21 am    Post subject: Reply with quote
as to your last question. I dont see why not
Personally I have never transferred routes from Mem Map to Satmap.
I have planned plenty of routes on Mem Map though and then printed them out and taken a paper copy[ screen dump] on my walk- along with OS map somewhere in rutsack and Satmap logging walk.
But each individual has different needs from/with the device in question.
howard40uk
PostPosted: Wed May 27, 2009 10:59 am    Post subject: Reply with quote
Ive just ordered my satmap and just wanted to know if it could be done as it may come in used to me at some point putting routes off memory map on to the a10
Tony_P1
PostPosted: Wed May 27, 2009 11:15 am    Post subject: Reply with quote
Just save the memory map route to your PC in .gpx format, then import the saved file into the A10 using Satsync. Works a treat.
Tony
howard40uk
PostPosted: Wed May 27, 2009 11:23 am    Post subject: Reply with quote
Thanks for your help the a10 looks a cracking device if the route distance walked is also accurate which im not sure about this will be money well spent .just bought the lancashre 50k area map too so cant wait till it arrives
philpugh
PostPosted: Wed May 27, 2009 2:51 pm    Post subject: Reply with quote
Tony
Just to stress the very important word in Tony_P1's reply - it's IMPORT. This is the option on SatSync that converts a .GPX file into a .MAP file that the ACTIVE 10 uses. If you just copy the .GPX file - nothing happens - except you have a bit less storage available Very Happy
Phil
22.051 (01 May 24)
