Pocket GPS World :: View topic - Warnings when under limit?
welshgasman
PostPosted: Sat Jan 24, 2009 12:47 am    Post subject: Warnings when under limit? Reply with quote
I've mentioned this before a good while back but due to being out of work, not had any real use of my i3 until last weekend.
Travelled just over 500 miles last weekend and found the i3 warning me of cameras and limits despite being well below those limits.
This was with the latest database as at 16/01/09.
Obviously if I stray over the limit I am grateful for the heads up, but when I am not, it is a little annoying.
Anyone have any ideas as to the cause.?
TIA
PostPosted: Sat Jan 24, 2009 12:52 am    Post subject: Reply with quote
Most probable is that you installed the last Speed Camera POI file using the KPH (default) setting rather than the MPH option within POILoader, re-install the database but make sure you select MPH as the unit of measurement and the problem should go away - Mike
