Pocket GPS World :: View topic - 720 and 8.3 'Help me' files missing
G4GVB
PostPosted: Fri Jan 09, 2009 9:50 pm    Post subject: 720 and 8.3 'Help me' files missing Reply with quote
I have just loaded 8.3 onto the 720 and found in the 'Help Me' section the Dr's, Police Stations and Pharmacy icons are all greyed out. I have downloaded the latest from TT's site - nothing. Any thoughts?
GO 750 LIVE v9.430 - v8.753612 EU map
XL 350 MT v9.151 - v8.75366 US Map
PostPosted: Sat Jan 10, 2009 11:28 pm    Post subject: Reply with quote
The usual problem with the "Help me" access to POIs was just not having any UK ones, but the icons weren't greyed out.
That sort of implies it cant find ANY of those POIs. Can you select any doctors, pharmacies etc from the normal Browse map / Find / POI near Home / Doctors etc. route? (even if they are all in Belgium!)
Presume you've tried a reset?
You could try adding the UK files from the second part of THIS TomTom page anyway, to see if that kick starts it.
G4GVB
PostPosted: Sun Jan 11, 2009 12:04 am    Post subject: Reply with quote
Hi, Yes done a reset and I can see all the Dr's etc from a POI search. I also have all the UK versions. When I was running v8.1 I could see them once, the second time I tryed they would be greyed out. To recover them I would have to connect to the PC (not Home) then I would just get one shot again. But with 8.3 they are greyed all the time... I will try your last suggestion
G4GVB
PostPosted: Sun Jan 11, 2009 12:06 am    Post subject: Reply with quote
.... Tryed that, they were the files I downloaded yesterday. Didnt help.... Thanks for your input anyway.
PostPosted: Sun Jan 11, 2009 12:46 am    Post subject: Reply with quote
Hmmm... It's a good one...
I'll keep thinking or hopefully someone else will remember something....
253
PostPosted: Sun Jan 11, 2009 12:47 am    Post subject: Reply with quote
My post is going to be less than useless, but here goes.
This happened to me, on my 720, and I was reading through the posts here and someone had posted the same and a reply. I tried it and it worked.
Bottom line though, I don't remember what I did!!
Never used it though - touch wood / fingers crossed.
Confused
G4GVB
PostPosted: Sun Jan 11, 2009 9:12 am    Post subject: Reply with quote
No not useless, it shows there is an answer. By the way my ONE does the same thing.
PostPosted: Sun Jan 11, 2009 10:43 am    Post subject: Reply with quote
Confused
The search feature can be quite handy at times like this, try Here - Mike
G4GVB
PostPosted: Sun Jan 11, 2009 11:05 am    Post subject: Reply with quote
I've been through search didn't find what I'm looking for. I have already loaded the Poi's from the TT site. I did try changing the name of a POI for B&Q stores I have to that of UK dentists TT poi. Once again the icons were grayed out, but again I was able to select it from the Show POI and it did display them on the map.
To me that shows that the POI is OK and that it is something in the app that mucks it up.
Would running 'Clear Flash' solve it? If I were to run that is there any problem loading everything back in after. I don't have any product codes etc for the maps I'm using. I do have a (windows) backup.
PostPosted: Sun Jan 11, 2009 11:14 am    Post subject: Reply with quote
There is no harm in trying the clear flash toolset, you have your backup so if it all goes pear shaped you can still recover the device.
Just one other question first, is there more than one map folder on the device, it has been seen before when people install files to the non active map folder on the device then wonder why the files don't show up. Try Change Preferences/ Manage Maps/ Switch Maps and how many are listed on the screen - Mike
G4GVB
PostPosted: Sun Jan 11, 2009 11:37 am    Post subject: Reply with quote
Just 2 maps the Canarys and Western Europe and the POI's are in Western Europe.
G4GVB
PostPosted: Sun Jan 11, 2009 12:09 pm    Post subject: Reply with quote
I have run the clear flash tool - no change, but I have noticed the phone for help works fine, it just the 'walk to' and 'drive to' that has the problem.
PostPosted: Sun Jan 11, 2009 12:48 pm    Post subject: Reply with quote
Take the device out to the car and see if it works once its got a position fix with you actually on a road - Mike
G4GVB
PostPosted: Sun Jan 11, 2009 12:55 pm    Post subject: Reply with quote
I've already thought of that one..... No change. Like I said on my last 'Phone for' works, walk and drive don't.
PostPosted: Mon Jan 12, 2009 1:04 am    Post subject: Reply with quote
Not had any brainwaves yet.
I guess the next step is to revert to an earlier software version (hopefully you have some backups, they will make it much easier to roll back) and see if it all comes good.
Then try a new download of v8.300 by deleting the existing one on the PC to force Home to download a new one.
