Pocket GPS World :: View topic - I keep getting an error message.
TomDavison
PostPosted: Sat Nov 22, 2008 8:21 pm    Post subject: I keep getting an error message. Reply with quote
On my 730T, I get (two or three times over a 5 hour journey) an error message on a scary red background in the top right corner of the screen "Unable to store map settings. File access error" After about 5 seconds it disappears, and as far as I can tell, the 730T continues to work normally. Is there any significance in this message, or is it just reporting a transitory error?
PostPosted: Sat Nov 22, 2008 8:33 pm    Post subject: Reply with quote
This error is usually down to the MapSettings.cfg file in the map folder eithing becoming corupt or more probably has been set to read only by some glitch.
Connect the device to the PC shut down TomTom Home if/ when it starts and use Windows Explorer to view the contents of the device, open the map folder and locate the "MapSettings.cfg" file, right click it and choose "Properties" from the pop up box, if the read only checkbox is ticked untick it and the problem should go away - Mike
TomDavison
PostPosted: Sat Nov 22, 2008 8:36 pm    Post subject: Reply with quote
I know that the forum is good, but 12 minutes to answer a query. That's bleedin impressive. Thanks Mike.
AlandEi
PostPosted: Sat Nov 22, 2008 11:05 pm    Post subject: Reply with quote
Too right Tom... these guys are the best... Thanks again from me...
Alan
Tom Tom Go 520 - Map UK ROI 720.1803 Navcore_8.204.9718.go40 - ( Loquendo TTS7 ) / RDS-TMC /Tyre... purchased the Go mainly for the itinerary feature
22.053 (15 May 24)
