Pocket GPS World :: View topic - Naming POI on Garmin
dlmjp1
PostPosted: Tue Sep 23, 2008 7:41 pm    Post subject: Naming POI on Garmin Reply with quote
How do i name poiin custom poi on the Garimin 200 Confused
PaulB2005
PostPosted: Wed Sep 24, 2008 8:23 am    Post subject: Reply with quote
What do you mean? They should already have names!
Pocketgps
PostPosted: Wed Sep 24, 2008 1:05 pm    Post subject: Re: Naming POI on Garmin Reply with quote
As Paul said, not quite sure what you mean.
But the lines in the file should be as follows:
;Longitude,Latitude,Name
-1.78041,53.60094,"Your Info Here"
or
-1.78041,53.60094,"Your Info Here","Second Info Line "
If you have alerts set then the poi will warn you and the "Your Info Here" will display on the screen.
If you called the saved file:
yourinfo.csv
then you need an icon with the same name, but saved with the .gif format:
You then use PoiLoader as normal. But remember that you need to load ALL of your custom poi's at the same time as PoiLoader will remove any existing ones. So always put them in one folder to reload to your Garmin.
Hope that helps and makes sense to you Laughing
22.051 (01 May 24)
