Posted: Thu Aug 14, 2008 7:48 am Post subject: |
Blue Bell Hill is located at TQ 757 613
For more information about this and the Emley Moor station try looking at This Web site, it also includes some tips/ tests you can try if reception is problematic (did you know that the Emley Moor transmitter fell down back in 1969?) - Mike |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Thu Aug 14, 2008 12:20 pm Post subject: |
Lost_Property wrote: | Quote: | Have you looked at other peoples digi aerials in your road because it might just need an extension pole to raise it up a bit. | My pole is about six feet above the chimney pot. It would be interesting to know how high I'd need to go. I wouldn't fancy a 12 or 18 foot one, especially when it's windy. I wonder if it could be something to do with the Howard School buildings partially blocking the Bluebell signals. |
You will need line-of-sight to the transmitter to get the best reception - any intervening building (esp close to you) will cause a problem.
We live in a barn conversion on mother-in-law's farm and our aerial points to Winter Hill some 20+ miles away - but clearly visible due to elevation. We have a multipoint amp/distribution system and have never had any problems. So... I fitted the same aerial brand/type (with aerial booster amp) onto my m-i-l's house only to find appaling reception. This was caused (mostly) by the roof of our house just getting in the way - so I moved the aerial to the edge of her house to clear our roof. That fixed the problem and she is more than happy. We are due to go all digital at the end of next year - so it needs to work
I wouldn't recomend a very tall mast - the forces when you get a strong wind will cause all sorts of problems with the mounting and test the structural integrity of your chimney / brickwork. _________________ Phil |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Aug 14, 2008 2:12 pm Post subject: |
Just checked again on the Freeview site and was greeted with.
Quote: | ME87BJ
Unfortunately, you won't be able to receive any Freeview channels now, or after your region has switched to digital TV. |
The default was the Dover transmitter, I then checked the Bluebell Hill one with the same result. Tried the other four in the list, just in case, but no luck there, so thats me like a turkey just before Christmas, well and truly....... _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15145 Location: Bradford, West Yorkshire
Posted: Sat Aug 16, 2008 10:42 am Post subject: |
cheers for the info - i'll try cover most of the points!
yes, we have correct aerial - got a brand new one installed august 2006 by professional company when we moved to freeview after dropping cable.
it's the entire muxA that causes issues not just channel 5, when i mentioned channel 5 i meant the mux that includes ch5 as opposed to just that channel.
dennis - mux = multiplex. there are 5 freeview 'channels' (known as a multiplex) and each multiplex contains between 5 and 15 individual channels.
for those with no freeview, have you tried looking at freesat from sky? a very basic sky package with freeview channels plus quite a few more - just pay a set up fee for the sky box for about £100 if i remember correctly. no monthly subscriptions.
i've no idea if the tv is also boosting the signal but the dvd recorder (with freeview) has no problems with the same signal so it may be the tv boosting it - i believe too strong signal is as bad as too weak?
MaFt |
Oldboy Pocket GPS Moderator
Posted: Sat Aug 16, 2008 2:12 pm Post subject: |
MaFt wrote: | i've no idea if the tv is also boosting the signal but the dvd recorder (with freeview) has no problems with the same signal so it may be the tv boosting it - i believe too strong signal is as bad as too weak? | Have you tried putting the aerial feed into the DVD Recorder and then the co-ax output from that, which usually goes via a Post-Amp, to the TV? _________________ Richard
Posted: Sat Aug 16, 2008 11:16 pm Post subject: |
Oldboy wrote: | MaFt wrote: | i've no idea if the tv is also boosting the signal but the dvd recorder (with freeview) has no problems with the same signal so it may be the tv boosting it - i believe too strong signal is as bad as too weak? | Have you tried putting the aerial feed into the DVD Recorder and then the co-ax output from that, which usually goes via a Post-Amp, to the TV? |
that's how i have it at the moment... i could fix it really easily by getting another cheapy asda freeview box but i'm stubborn and dont want to have an extra box when my tv already has it!
MaFt |
Posted: Sun Aug 17, 2008 9:28 am Post subject: |
What happens if you plug the aerial feed co-ax directly into the TV? Is there an improvement?
It could be the Post Amp is doing too much, or it might be faulty. _________________ Richard
Posted: Sun Aug 17, 2008 9:13 pm Post subject: |
it also did it before i got the dvd-recorder...
it's a cheap daewoo tv so maybe if it's not resolved by the 2011 switch over then i'll buy a nice new one ;)
MaFt |
Posted: Mon Aug 18, 2008 6:43 am Post subject: |
MaFt wrote: | if it's not resolved by the 2011 switch over then i'll buy a nice new one ;) | Best excuse/reason I've heard in a long time. _________________ Richard
GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Mon Aug 18, 2008 11:35 am Post subject: |
New car, wants new TV - he'll want paying next
Perhaps another way around this problem would be to buy a digital recorder (PVR), which ought to boost the signal in the same way as your DVD recorder. This will allow you to pause TV, record one channel whilst watching another, record two different channels simultaneously.
There's a 500GB model - £149.99 from Argos
However, Freesat has more channels available and you should be guaranteed good reception. Freesat HD boxes are due to be released later this year. _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
aj2052 Frequent Visitor
Posted: Mon Aug 18, 2008 1:27 pm Post subject: |
Quote: | Perhaps another way around this problem would be to buy a digital recorder (PVR) |
I dont think this will actually solve this problem, as said earlier I have the same problem using a PVR, freeview keeps breaking up on mine although absolutely fine on three other cheapy set top boxes, I have changed aerial three times and fitted 6 way amplifier/splitter adjacent to Aerial in loft and cannot cure, But having said that I would thorougly recommend a PVR, but make sure its twin tuner, at the moment you can watch one prog on the Analogue TV whilst recording 2 others on different channels on the PVR or record one Freeview whilst watching another freeview, it will certainly change your viewing habits, i usually have a load of films recorded which i never have time to watch and at the moment it is being utilised to record the earlier morning kids cartoons for the grandkids, I am not an early riser.[/i] _________________ Moto G5s Plus, Sygic 17.4.8 |
WLMOATE Regular Visitor
Posted: Mon Aug 18, 2008 7:15 pm Post subject: |
Having an antenna amplfier at the TV is quite pointless due to the signal loss has already occured due to the lenght of coax etc . Antenna amps should be fitted at the antenna head.
For people with poor reception have you had the correct band natenna fitted for your region. A lot of installers say they are proffesional but just buy wideband antennas which work but don't give the best results in poor signal strength areas .
Coax is another major issue for poor signal strength as a already weak signal from the antenna can be lost sent over any lenght of coax . The brown or white coax sold by popular DIY stores is sub standard.
For details of approved antennas/coax and installers check here www.cai.org.uk _________________ Wayne
MY-SOS, Benefon TWIG, DriveSmart, Wayfinder |
Posted: Mon Aug 18, 2008 11:13 pm Post subject: |
wayne,
the installers were definitely cai approved! that was one thing i checked before booking anyone!
we live on top of a hill with a pretty clear view of emley moor mast so i doubt it is a signal issue in my case. the fact that the old el-cheapo asda freeview box as well as jvc dvd-recorder have perfect freeview reception confirms this.
i think i'm starting to go down the 'not very good receiver in the telly' theory... such a shame really, i don't want a new telly..! ;)
MaFt |
Posted: Tue Aug 19, 2008 6:35 pm Post subject: |
That could be the case a lot of people think all recievers are born equal, which is not the case hence the difference.
Just going out on a limb your issue isn't caused by excessive signal strength? Have you tried an attenuator? _________________ Wayne
Posted: Tue Aug 19, 2008 8:58 pm Post subject: |
WLMOATE wrote: | That could be the case a lot of people think all recievers are born equal, which is not the case hence the difference.
Just going out on a limb your issue isn't caused by excessive signal strength? Have you tried an attenuator? |
it could be actually... where would i get one from? and what sort of price are they? if maplin sell one i can always return it after a few days if it doesn't work ;D
MaFt |
