Pocket GPS World :: View topic - TomTom ONE V2 won't turn on......
daveXIII
PostPosted: Mon Aug 04, 2008 3:44 pm    Post subject: TomTom ONE V2 won't turn on...... Reply with quote
Hi guys, me again.
Just upgraded my ONE V2 to firmware 7.162 and added Western Europe and USA/Canada maps (both v7.20).
Now then, if my device is connected to a charger, it starts up and shuts down normally via the power button.
If I disconnect the charge lead, I cannot start the unit unless the charger is reconnected.
However, once the unit is up and running, I can remove the charger and it will continue merrily on internal battery power.
At first I thought that it was due to the internal battery being low, but having charged it up, it makes no difference.
Finally, if I remove and replace the SD card whilst the device is powered down, I can turn it on. This appears to result in some sort of reset as it takes longer to power up, and you get the blue/yellow progress bar across the bottom.
Any ideas? Just spent hours fiddling with this and it still isn't right!!
daveXIII
PostPosted: Mon Aug 04, 2008 3:50 pm    Post subject: Reply with quote
Forget to mention, I've tried the bent paper click in the reset button routine.
Didn't seem to help....
Thanks. Dave.
metradio
PostPosted: Sat Aug 30, 2008 4:51 pm    Post subject: Reply with quote
The wife had exactly the same problem, same model and program version.. Like you I played around with the reset thing to no avail..
In desperation I had a rummage on TomTom's support pages, with surprise I found the following DID cure the problem:
Question:
My TomTom device won’t turn on. How can I reset my device?
Answer:
In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
To reset your TomTom device, do the following:
1. Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
2. Remove the SD card.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds.
4. Turn your device on.
Press the On/off button for at least 5 seconds.
5. Insert the SD card
Mike
22.052 (08 May 24)
