Pocket GPS World :: View topic - Route Plan changes
Route Plan changes
FrequentFlyer
PostPosted: Tue Jul 01, 2008 8:47 pm    Post subject: Route Plan changes Reply with quote
On the Route Plan screen...(the one that shows a cross section of your walk,) there are a number of boxes which I assume are fixed above the cross section. But what about the 'small print' below the cross section.... can any of this data be user changed as I don't need to know the straight line distance, Average, Average Moving, and Max mph etc. I would like to be able to insert my own info from the 4/6 box set up in settings.
And when I change into 'Card' mode, how can I easily determine which Way Point is which on the finished walk/route. (Not very clear I'm afraid!)
jonesbach
PostPosted: Wed Jul 02, 2008 9:17 pm    Post subject: Re: Route Plan changes Reply with quote
MAIN MENU - Route Menu - 'Select Route' - Edit - 'Select Edit Waypoints' - Edit - 'Select the Waypoint to Edit' - Edit - 'Select Edit Comments' - Edit
and away to go.
22.054 (22 May 24)
