dhn Frequent Visitor
Posted: Sat Jan 24, 2009 1:02 pm Post subject: 3rd Party Altitude 'Plug-In' |
Admin Edit: Topic split from original disussion here.
mikealder wrote: | It doesn't disable the "zoom in" function but does alter how you use it, try putting your finger below or to the right of the + sign (where the altitude displays if you have put that option on) and slide your finger over to the + sign, the map will now zoom without taking a screen capture - Mike |
Mike......
Where does one find the 'altitude' option and how does one implement it?
TIA _________________ David |
Darren Pocket GPS Staff
Posted: Sat Jan 24, 2009 1:19 pm Post subject: |
dhn wrote: | Where does one find the 'altitude' option and how does one implement it? |
I think I'm correct in saying this is a third party applet that Mike is evaluating. _________________ Darren Griffin - Editor |
Posted: Sat Jan 24, 2009 1:26 pm Post subject: |
You can download the files needed from Here this is a third party add-on application written by "Joghurt" whose web site can be found Here it contains quite a few other add-ons for the TomTom devices, although as yet the Height app hasn't been listed on the main site.
For some additional information on the application and how to change it from Meters to Feet and apply local height offset figures have a read of This Thread - Mike |
Posted: Sat Jan 24, 2009 1:42 pm Post subject: |
Thank you both..... _________________ David |
alanji Lifetime Member
Posted: Tue Jan 27, 2009 11:08 am Post subject: Height programme |
Joghurt has issued release 5 http://gps.dg4sfw.de/ of his Height programme which, in addition to allowing choice of ft or meters, allows change of font size. I have simplified (I hope) the instructions in the link provided by Mike, above.
1) Extract all files once downloaded - you can then (I think) use Home to install or proceed as follows
2) Open the Height_5.cab file – you should have 3 files - ttn, height.cfg and height.so
3) copy the ttn file to the root (top) directory of the internal or sd card (whichever the map folder is in) on your TomTom
4) Create a folder called “Height” in the same place on your TomTom
5) Edit the Height.cfg file if required, using a word/text programme
6) Copy the height.cfg and height.so files to the “Height” folder on your TomTom
Many thanks to Yoghurt for providing this. _________________ Alan
Go 750 LIVE Europe Map 870.3406
Go 720 W Europe Map 865.3245
One XL W Europe. Map 715.1689
Dell Axim & TT3
Psion 5mx & Routeplanner |
Posted: Tue Jan 27, 2009 11:20 am Post subject: |
Neat little app, works well. _________________ Darren Griffin - Editor |
Andy_P Pocket GPS Moderator
Posted: Tue Jan 27, 2009 6:41 pm Post subject: |
...and it's already updated (from the beta downloads) on the "Third Party Apps." list  |
philpugh Lifetime Member
Posted: Wed Jan 28, 2009 12:18 pm Post subject: |
Darren wrote: | Neat little app, works well. |
But not on my 720 with V8.32 running.
I get a number displayed which changes depending on which menu is being displayed. On the map it stays at the same figure (25401) no matter what! Looks like it has been broken now  _________________ Phil |
Posted: Wed Jan 28, 2009 12:48 pm Post subject: |
That could be a known issue and it is displaying the "page id number".
Have a look at the explanation (and cure?) from the programmer HERE and see if it helps. |
Posted: Wed Jan 28, 2009 3:32 pm Post subject: |
Thanks Andy That fixed it. You need to do this if you select different map colours by the look of it.
It works (well just as much as any other GPS altimeter does ) I'm somewhere between -3 and +35m here in Warrington and that's in the time it has taken me to write this.
I must try to find the offset to the WGS84 spheroid for around here. I think that where I am at present is at about 5-10m on the OS maps _________________ Phil |
Posted: Wed Jan 28, 2009 10:33 pm Post subject: |
Update on "Height" (maybe we need to split this into it's own topic?)
Currently it is not working on x00 and x10 models. Joghurt is investigating... |
Posted: Thu Jan 29, 2009 2:36 pm Post subject: |
philpugh wrote: |
I must try to find the offset to the WGS84 spheroid for around here. I think that where I am at present is at about 5-10m on the OS maps |
If anyone is really interested I did some very crude height averaging when parked up at home last night (5 mins of data manually logged every 5 secs - roughly). Average came to 65mtrs - OS have us at 60mtrs - the contour line goes straight through our kitchen. Given the OS have a +/- 4.5 mtrs accuracy on these I would say that's not too shabby. _________________ Phil |
stuart Frequent Visitor
Joined: 20/04/2003 11:51:10 Posts: 405 Location: Dorset, England, Great Britain
Posted: Mon Feb 02, 2009 11:45 pm Post subject: |
Thanks Mike. I only keep my iPaq charged up and running as a novelty really. And like alanji, I still have my Psion 5mx working. How sad is that. But I have got the screen grab working OK on the iPaq. |
Posted: Tue Feb 03, 2009 10:57 am Post subject: |
stuart wrote: | And like alanji, I still have my Psion 5mx working. How sad is that |
Hi Stuart,
Not sad at all. I still use my Psion extensively - diary, all accounts, share portfolio, numerous spreadsheets, my own OPL programmes. It was (and is) a great machine and it hardly ever crashes!
Must admit the last time I used Routeplanner was on a trip to Eire in 2006 when there was no map of Eire on Navigator 3. _________________ Alan
Dell Axim & TT3
Posted: Tue Feb 03, 2009 11:32 am Post subject: |
alanji wrote: |
Must admit the last time I used Routeplanner was on a trip to Eire in 2006 when there was no map of Eire on Navigator 3. |
Must dust mine off and flash it up again for old times sake.
Back on Topic. As Mike said, Height does NOT work on PPC Navigator. Well I can't make it work.  |
