Pocket GPS World :: View topic - POI capture - Nuvi 250W
Beefheart
PostPosted: Sun May 18, 2008 2:49 pm    Post subject: POI capture - Nuvi 250W Reply with quote
Is it possible to capture or mark a Point of Interest whilst driving?If so, how?
Any tips, please.
Thanks,
John
PaulB2005
PostPosted: Sun May 18, 2008 7:35 pm    Post subject: Reply with quote
Touch the screen and hold your finger there for a second or so and it'll record a favourite called 001. Then next will be called 002 etc Then when you can a chance you can rename the favourites.
Probably not best to do any of this if you are driving.....
PostPosted: Mon May 19, 2008 8:18 am    Post subject: Reply with quote
or, tap the screen (without holding it down) then it will show a 2d map with a 'dot' where you pressed the screen. pull over and fine tune the position on the map then do the naming and saving.
obviously this method needs you to be able to pull over!! if not then use paul's above!
PaulB2005
PostPosted: Mon May 19, 2008 9:07 am    Post subject: Reply with quote
I think MaFts method is better because i can only make my method work by accident when i don't want it to!
