Pocket GPS World :: View topic - TT 920T when using "Minimise Delays" says "No
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
sdm197
PostPosted: Mon May 12, 2008 5:51 pm    Post subject: TT 920T when using "Minimise Delays" says "No Reply with quote
Hi All,
I plugged in my TMC antenna earlier to look at a route, it said there were delays as there was an accident. So for the first time ever I told it to "minimise delays" it does its searching and comes up with "No Route Found" Mmm very useful, so I try it with some other routes again with warnings for narrow lanes in two stretches, all with the same result!
Is this normal?
SDM197.
Tim Buxton
PostPosted: Mon May 12, 2008 5:57 pm    Post subject: Reply with quote
It probably is (normal) at the moment, but the problem is being worked on. It stems from the fact that delays as actual times aren't being reported to, or possibly interpreted by, the device. This means that the device can't calculate routes using the minimise delays option simply because it doesn't know what the delays are!
You can still use the avoid incident option, though.
Tim
sdm197
PostPosted: Mon May 12, 2008 6:41 pm    Post subject: Reply with quote
Hi Tim,
Thanks for the reply, yes that makes sense now, the old TMC used to give an indication of the delay normally 1 minute Surprised
But now it never shows the delay time,
Thanks for putting my mind at rest,
SDM197.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
21.014 (25 Jan 23)
