Pocket GPS World :: View topic - Etrex routes and Waypoints
afcbrichard
PostPosted: Sat May 03, 2008 3:09 pm    Post subject: Etrex routes and Waypoints Reply with quote
I have just bought an Etrex H and when I create a route the pointer page appears to indicate that the next waypoint it selects is the nearest waypoint not the next one in the order of the route if i choose a circular route and select 001-009.
If I select 009 -001 then it shows 009 in the pointer page but does not appear to go to 001.
Sounds confusing I know but can anyone help?
I can obviously get by by using GO TO and selecting each waypoint as I go which appears to work OK.
Prodnose
PostPosted: Sat May 03, 2008 7:14 pm    Post subject: Reply with quote
Your complaint must top the list of Garmin irritants. The Etrex logic is that you want to travel from A to Z. You may enter B, C, D etc to help you on your way. But if, say, when reach E you pass close to X, the logic decides that you should go to X because it is the shortest way to your objective Z. That you want to take a circuitous route or that you must cross a river to travel from E to X is just hard luck.
The classic problem is when taking a circular walk is that you are immediately directed to end point: logical but ***** annoying!
The solutions are either to navigate from one waypoint to the next using "Goto" or break the route into two or more parts. If the route more or less linear the problem doesn't arise
Harry
afcbrichard
PostPosted: Sun May 04, 2008 8:33 am    Post subject: Reply with quote
Thanks Prodnose
At least I now know that the etrex logic is rubbish and that my garmin is working, I will continue to utilise the GO TO function as most of my walks are circular.
21.021 (01 Feb 23)
