Pocket GPS World :: View topic - Xpedition Not Saving
Awthin
PostPosted: Sun Sep 02, 2012 6:41 pm    Post subject: Xpedition Not Saving Reply with quote
I seem to no longer be able to save routes in My Xpedition. Has anyone seen this before and any known fix?
Awthin
LostMike
PostPosted: Sun Sep 02, 2012 8:53 pm    Post subject: Reply with quote
Hi Awthin.
It still seems to be working for me though I am not sure it saved where I expected. I thought I saved my test route in a folder but it went into the Xpedition root directory. Don't know if that helps.
I also noted a window about European legislation and cookies. It is just possible that a cookie change has had an impact. Look forward to your findings!
Good luck.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
Awthin
PostPosted: Mon Sep 03, 2012 10:02 pm    Post subject: Reply with quote
Apologies for not being clearer. I mean that when I try to Save or Save As in the Planner component it just does nothing. Is there some kind of limit on how many routes you can have saved perhaps?
Awthin
Awthin
PostPosted: Tue Sep 04, 2012 6:35 pm    Post subject: Reply with quote
I got this response back from Satmap. Deleting the entry as advised cleared the problem.
"Can you try opening up the planner page and right click on the mapping area and click on ‘Silverlight’. Then open the ‘Application Storage’ tab and in the bottom right hand corner is a box labelled ‘enable application storage’. Is this ticked? If not it needs to be.
If that does not work can you try the following – go to the same link (open up the planner page and right click on the mapping area and click on ‘Silverlight’. Then open the ‘Application Storage’ tab) and check the ‘current (MB)’ score next to the www.satmap-xpedition.com link. If it equals 1.0 then can you select it and ‘delete’. Then close and re-open the browser and try again. "
LostMike
PostPosted: Wed Sep 05, 2012 3:07 pm    Post subject: Reply with quote
Fascinating - thanks Awthin!
LostMike
Satsync 1.525
22.074 (24 Jul 24)
