Pocket GPS World :: View topic - route for 920t
route for 920t
garw40
PostPosted: Mon Feb 25, 2008 2:40 pm    Post subject: route for 920t Reply with quote
just upgraded 700 to 920t when i set a route the 920t takes me through lanes whitch is different to my 700 any help i tow a caravan ! Confused Confused
PostPosted: Mon Feb 25, 2008 3:16 pm    Post subject: Reply with quote
There's no specific option to avoid small roads and never has been.
The only options you can try are in Change preferences / planning preferences, where you can choose to avoid Motorways and a few other things.
Are you telling it to plot the "fastest" route? If you opt for "shortest" it will always use the most direct route which is bound to use some small roads that "fastest" will avoid.
garw40
PostPosted: Mon Feb 25, 2008 8:23 pm    Post subject: route Reply with quote
no i allways tell it the fastest route but it takes me down lanes when 700
did not !!
PostPosted: Mon Feb 25, 2008 9:04 pm    Post subject: Reply with quote
Then it must be either the speeds logged for road sections on the new map or new routing algorithms in the new software.
Either way, I don't think there is anything you, as an end-user can do about it.
Can you give an example so others can try it?
What happens if you hit "calculate alternative"?
22.053 (15 May 24)
