ADJenkins Occasional Visitor
Posted: Sun Feb 24, 2008 3:55 pm Post subject: Suction mount on fuel tank? |
Has anybody tried this? I was thinking (as mounts for the Garmin i3 are few and far between) of trying mine stuck to the fuel tank using the standard windscreen mount. The tank is nice and flat in the centre on a Triumph Thunderbird Sport. The bit that bothers me, occasionally in the car it will drop off the screen and land in my lap. At 70-80mph if it pops off the tank................... |
DennisN Tired Old Man
Posted: Sun Feb 24, 2008 7:54 pm Post subject: Re: Suction mount on fuel tank? |
ADJenkins wrote: | At 70-80mph if it pops off the tank................... |
Get a 2 foot length of that heavy duty anchor chain you use to lock the bike wheel to a lamp post, weld one end to the mount and the other to the brake lever. When/if it does fall off at 70-80mph, it'll automatically apply the brake to help you get back below the speed limit. _________________ Dennis
Two of them are obesiting!! |
Posted: Sun Feb 24, 2008 8:29 pm Post subject: |
Naturally I had considered this option, however my Abus chain is just a bit too long and would result in my poor little Garmin bouncing along on the tarmac. Not a good position for a Sat Nav..
You've given me an idea though, some sort of tether wire/cable just in case. |
Posted: Sun Feb 24, 2008 8:47 pm Post subject: |
Back in the good old days, in my misspent youth of 60-ish years ago, I saw many cowboy films. The answer to your problem is to swing down to hang out of view of the Indians off the saddle - you'd see the satnav piece of cake (and the Indians wouldn't get you either)! You don't get that with DVDs these days.
Feed the tether wire through a net bag so that it draws into it and doesn't go tapping your lower bits. _________________ Dennis
Posted: Sun Feb 24, 2008 8:56 pm Post subject: |
If you are serious about using the i3 on the bike; mounting issues are one thing, but I would look at sticking one of the dash mount disks to the top of the tank before using the suction mount to attach the i3 to its surface.
For restraint there is little option with the i3 other than to open the case, put it face down on the table and use a Torx bit number 6 to remove the four screws securing the case together, once apart you can drill a couple of holes in the rear shell and pass a lanyard through it.
Please bear in mind if the i3 were to fly off the bike at motorway speeds it could easily go through a car windscreen so the method of attachment needs to be secure, have a look at the mounting systems offered by RAM these rely on a physical connection between the bike and device - far more reliable than the suction units which are not suitable on a bike IMHO - Mike |
Posted: Mon Feb 25, 2008 11:15 pm Post subject: |
Cheers Mike, These RAM mounts are just what I've been trying to come up with using various ideas with 17mm beads (which the Garmin uses). If I had a lathe (or access to one) I was going to turn something to fit on the mirror stalk or similar. I've mailed RAM to find out more about a mount with the required 17mm ball. My 'suction mount/fuel tank' was the last resort.
Despite all my searching with Google (and I know a few tricks) I never found a link to RAM.
Andy. |
surreypete Occasional Visitor
Posted: Tue Feb 26, 2008 9:38 pm Post subject: |
How did you get on with this reply ADJenkins?
I want to mount my Nuvi 310 to the handlebars of my motorbike and was thinking of how to do it, I even contemplated putting the sucker mount on the speedo glass but thought that a bit dodgy, besides I would block the speedo and in this day and age that's very risky.
I'm thinking along the same lines, fit a clamp to the handlebar with the same size ball that the Nuvi mount has so it just pops on, although still worried that the vibrations of the bike would make it pop off. |
Posted: Tue Feb 26, 2008 10:08 pm Post subject: |
Perhaps something like This for the Nuvi, coupled to This for the bike might be what you are looking for, there are plenty of other bike addaptors though so check the range out fully before committing to a particular device - Mike |
Posted: Thu Feb 28, 2008 7:49 pm Post subject: |
I've had a reply from RAM Mounts. They do a fitting for the rear of the i3 (Part No. RAM-HOL-GA22) which you then fit to one of their arm/handlebar fittings (Part No. RAM-B-149Z or RAM-B-149ZA). These are all available from www.gpsw.co.uk
However, I've decided to go down another route. If I remove one of the bolts holding the clutch lever clamp on and replace it with one with a 17mm ball on the end (see my drawing at http://www.rover75.org.uk/GPS-Bolt.jpg ) it will be far neater. I'm having a local bespoke engineering company turn it for me next week using stainless steel, around £20. I know it's a lot for a 'bolt' but for one-off engineering it's not bad.
Andy Jenkins. |
