Pocket GPS World :: View topic - Own Pois in I-Go
Own Pois in I-Go
mark1968
PostPosted: Fri Oct 19, 2007 7:34 am    Post subject: Own Pois in I-Go Reply with quote
I have a number of sub groups set up as pois, but have been unable to edit a saves poi into the correct category.
I follow the edit poi process select ok at the end and the poi sits in the last category used not the one selected.
Does anyone know where they are kept and if we can edit then ouside of the program?
Please follow me on twitter @mdyson1968
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Border_Collie
PostPosted: Fri Oct 19, 2007 4:36 pm    Post subject: Reply with quote
A straightforward Edit and changing Group can put the POI's in the wrong group but the following works for me.
Select POI - Edit - Select Group - arrow back, then click OK.
mark1968
PostPosted: Fri Oct 19, 2007 5:45 pm    Post subject: Reply with quote
Thanks that'swhat I have been doing, the poi changes into the correctgroup until I exit the prog normally. When I go back in the poi has reverted back to its original group.
Border_Collie
PostPosted: Fri Oct 19, 2007 6:11 pm    Post subject: Reply with quote
Thanks that's what I have been doing, the poi changes into the correctgroup until I exit the prog normally. When I go back in the poi has reverted back to its original group.
I may have missed out an instruction. Embarassed
POI - Edit POI - Change Group - Tap on POI Name then Done. Tap arrow - Tap OK.
mark1968
PostPosted: Fri Oct 19, 2007 8:39 pm    Post subject: Reply with quote
I have tried that as a solution but again as soon as I exit the progran, the POI resets back to the origional group.
Border_Collie
PostPosted: Fri Oct 19, 2007 9:06 pm    Post subject: Reply with quote
It can be done, maybe my memory is playing up.
On first install all my POI Groups stayed as they should but I hard re-set my Mio. I re-installed iGO, after which I found I had the same problem as you are getting.
I 'messed' around experimenting with the Groups and eventually got it right. Problem is, it appears I can't remember what I did. Sad
Idea I'll experiment with mine and try to find out what I did.
mark1968
PostPosted: Sun Oct 21, 2007 9:17 am    Post subject: Reply with quote
I have resolved this issue by ising a free applicatgion called I-GO POI Explorer. This application allows you to edit your POIs on a PC and also import POIs from TOMTOM etc.
The download can be found here http://inetcom.hu/mick/igo/
bakerman
PostPosted: Thu Jan 03, 2008 1:00 pm    Post subject: Reply with quote
Has anyone got this i-go poi explorer working, mine bombs out everytime I try and use it.
22.034 (27 Mar 24)
