Pocket GPS World :: View topic - CP7 bug? - reverts to 2D view after using POI menu
PostPosted: Wed Feb 20, 2008 12:03 pm    Post subject: CP7 bug? - reverts to 2D view after using POI menu Reply with quote
whenever i use the 'find poi' menu option the navigation screen ALWAYS reverts back to 2D mode regardless of what it was on before.
does this happen with anyone else or just me?!
nivek22
PostPosted: Wed Feb 20, 2008 1:56 pm    Post subject: Reply with quote
I use the 3D view all the time.
I've just used the search to enter a POI as a destination & menu, nearby POI to find a speed camera. Each time my 3D view is retained.
Can you explain in more detail the steps that you've taken and I'll try to replicate it exactly.
PostPosted: Wed Feb 20, 2008 2:03 pm    Post subject: Reply with quote
cp7 normal map view in 3d (not navigating anywhere)
menu / nearby poi
select a group - eg petrol station
select nearest and 'ok'
... an it stays in 3d...
hmm.... i was navigating this morning so i'll try it again in the car in a bit doing exactly the same as above but while navigating!
nivek22
PostPosted: Wed Feb 20, 2008 2:22 pm    Post subject: Reply with quote
Yep,
I've had a play while in navigation mode and it does change to 2D view.
PostPosted: Wed Feb 20, 2008 8:49 pm    Post subject: Reply with quote
i had a play and it didn't so i must have been doing something slightly different...
i'll try AGAIN tomorrow!!
PostPosted: Thu Feb 21, 2008 11:42 am    Post subject: Reply with quote
been playing again!
it seems that once you get to the 'details' part of selecting a poi and it shows it's position on a map (which, coincidentally, is 2d) then your view is changed to 2d whether you cancel or continue to route to the new poi.
also, i just noticed the 'view shortcut button' option so now i have a new button on the map page to quickly switch it back to 3d when it canges it to 2d!
22.051 (01 May 24)
