Pocket GPS World :: View topic - New to Nuvi 200 Please Help
gazcoo
PostPosted: Wed Jan 09, 2008 10:08 pm    Post subject: New to Nuvi 200 Please Help Reply with quote
I have just bought a Nuvi 200. I also have a street pilot series and have updated this many times using the POI Loader. I am trying to do the same with my new Nuvi, however when I plug it in it does not launch the Poi Loader and if I do this manualy it says it cannot find a gps connected.
Can anyone help?
philpugh
PostPosted: Thu Jan 10, 2008 6:13 pm    Post subject: Re: New to Nuvi 200 Please Help Reply with quote
gazcoo wrote:
What cable are you using? With my 660 I have several 'cheapo' USB cables that give the same effect you are seeing. My GARMIN supplied cable (came with 660) works fine - as do a few other USB cables I have.
When you plug the nuvi into your PC it should revert to the start-up splash screen and show a computer icon towards the middle lower edge of the screen. Your PC (as stated above) should then see the nuvi as a drive (or two if you have an SD slot).
Also I don't believe POILoader will auto-load - at least it doesn't with my 660 - but that could be due to my PC - it's got a lot of things attached and it just may not be configured correctly.
Phil
gazcoo
PostPosted: Sat Jan 12, 2008 9:37 pm    Post subject: Nuvi Prob Reply with quote
I am using the cable that came with my old garmin. I am seeing the computer icon and can see the drives/folders on the nuvi, however I cannot get the poi loader to see the nuvi, it just says that no GPS is connected.
Regards
gazcoo
kattman
PostPosted: Sun Jan 13, 2008 12:00 am    Post subject: Reply with quote
I do it all from a sd card, Just make a Garmin folder, and have the Poi loader point to it. when the card is put into the nuvi it will ask you if you want to transfer it to the nuvi's memory!
gazcoo
PostPosted: Mon Feb 18, 2008 6:50 pm    Post subject: Nuvi Reply with quote
Many Thanks for the help.
It turned out to be the cable as you said. I thought I was using the Garmin one, however it turned out to be a cheap one.
I found my Garmin one and it now works fine.
Regards
Gazcoo
22.052 (08 May 24)
