Pocket GPS World :: View topic - Removing waypoints from nuvi 200?
kattman
PostPosted: Sat Feb 23, 2008 5:14 pm    Post subject: Removing waypoints from nuvi 200? Reply with quote
Anyone know how to remove Waypoint that are stored in the "Favorites"
using a computer?
Everytime I change the "current.gpx" file to remove them, The file
allways gets restored!
Does the Nuvi have it backup someware?
Kattman
inspiredron
PostPosted: Sat Feb 23, 2008 6:34 pm    Post subject: Re: Removing waypoints from nuvi 200? Reply with quote
using a computer?
Kattman
Why do it on a computer? On my 660 it deletes as follows:
Where to? - Favourites - Select the one you want to remove - Edit - Delete
Wink
I guess that your 200 will be a similar logic.
kattman
PostPosted: Sat Feb 23, 2008 10:49 pm    Post subject: Reply with quote
I need to delete 78 waypoints! It will take some time, and screen taps!
ie " are youre sure questions"!
PhilHornby
PostPosted: Sun Feb 24, 2008 12:17 am    Post subject: Re: Removing waypoints from nuvi 200? Reply with quote
kattman wrote:
Anyone know how to remove Waypoint that are stored in the "Favourites" using a computer?
You can't Sad
He also wrote:
Everytime I change the "current.gpx" file to remove them, The file always gets restored!
Current.gpx is the backup...
When the Nüvi boots, it scans the file system (and the SD card) for .gpx files. Any new entries that it finds are added to the list of Favourites. This list is in a location that is inaccessible to the outside world. For whatever reason - accident probably - Current.gpx is included in this scan. When all the new Favourites have been added, the list is written out to Current.gpx, overwriting its previous contents.
To delete Favourites, you have to use the functionality built-into the Nüvi's interface - i.e. manually. You can delete them one at a time, or blow all of them away at once. The one thing you can't do, is selectively delete batches of them.
