Posted: Mon May 12, 2008 5:51 pm Post subject: TT 920T when using "Minimise Delays" says "No
Hi All,
I plugged in my TMC antenna earlier to look at a route, it said there were delays as there was an accident. So for the first time ever I told it to "minimise delays" it does its searching and comes up with "No Route Found" Mmm very useful, so I try it with some other routes again with warnings for narrow lanes in two stretches, all with the same result!
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Mon May 12, 2008 5:57 pm Post subject:
It probably is (normal) at the moment, but the problem is being worked on. It stems from the fact that delays as actual times aren't being reported to, or possibly interpreted by, the device. This means that the device can't calculate routes using the minimise delays option simply because it doesn't know what the delays are!
You can still use the avoid incident option, though. _________________ Tim
