Pocket GPS World :: View topic - POI warnings
POI warnings
Fatdave42
PostPosted: Sun Dec 16, 2007 4:23 pm    Post subject: POI warnings Reply with quote
I have got a TomTom 910, on my rider I can get a .ogg file to play as the worning fot a POI, but I can not get it to woek on my 910.
I am ao have problems that my pois that I have put on the 910 do not show up on the map. I have told them to be visibal. I have also just tryed selcting just 2 of them, so not to overload the 910
Any Idears?
PostPosted: Sun Dec 16, 2007 6:53 pm    Post subject: Re: POI warnings Reply with quote
It is slightly different on the 910, because you have TTS. When you go through the options in Warn When Near the 2nd Page asks to select a type of warning. Select Sound Effect and if an OGG file is present it will use that. You MUST Tap YES to the question Is this the sound you want to select? otherwise the 910 will just Freeze. (A bug Rolling Eyes )
If there is no OGG File you will get a Sound Selection Screen.
Very often you have to zoom in fairly close to see POIs. You could also be looking in the area where there are none. Smile
In Browse Map, use the Find button to locate one of the POIs and see if that appears on the screen.
If you only have them set up in Warn When Near, then they don't appear in Browse Map, but will appear in the Navigation Map when pass within range of them.
Even if POIs are not Enabled to appear on the Screen, you can still Navigate to, or Via, them
22.052 (08 May 24)
