Pocket GPS World :: View topic - freedom to add and remove maps
wig
PostPosted: Tue Feb 19, 2008 10:19 am    Post subject: freedom to add and remove maps Reply with quote
I have a pocket PC and have installed TomTom Nav 6 from the DVD disc that came with maps and product code.
Is it possible to install and uninstall maps on an unlimited basis to my pocket PC or does the software prevent this as part of an anti-pirating feature?
I ask because my SD card is limited in size and I only need some maps when on holiday for a brief period and would like to remove them after the holiday and replace them if I return to the country. I will only be using the same pocket PC each time. I dont want to uninstall a map only to find I cant install it again!
PostPosted: Tue Feb 19, 2008 10:33 am    Post subject: Reply with quote
The maps are locked to the device so, as long as it is the same device you use each time there would be no issue.
Given that memory cards are very cheap these days the easiest would be to get a bigger card or use one card for the map and swap it in/out as necessary.
The other alternative is to just backup the card to your PC. No need to re-install every time, when you need it copy the backup back to the card, when you don't, back it up to the PC again.
wig
PostPosted: Tue Feb 19, 2008 10:50 am    Post subject: Reply with quote
thank you for the prompt reply
22.052 (08 May 24)
