cheese Occasional Visitor
Posted: Thu Jul 19, 2007 10:23 pm Post subject: XDA IIi and Bluetooth GPS reciever with TT5 problems |
Hi all, apologies if this has been covered before but I couldn't find an answer when i searched.
I have a XDA IIi and TT5 I have bought a bluettoth GPS reciever and and am trying to pair the two and then get TT5 to recongise it. I was able to pair the device, but on the instructions, it say the service available shuld be SSP Slave, but I only get SSP.
The XDA shows that the devices are pair and transmitting but only outgoing, nothing incoming.
And when I go in to TT5 it tells me to pair the devices first and can't see anything. Am i doing something wrong??
Any help appreciated.
thanks
john |
Posted: Thu Jul 19, 2007 10:30 pm Post subject: |
forgot to mention,
the Secure connection box is unchecked. |
Posted: Fri Jul 20, 2007 9:23 am Post subject: |
Make sure flight mode is OFF, then try the "Other Bluetooth GPS" setting, this way you can assign the BT port from the list presented (its either com5 or 6 on your device IIRC)
You only need to set an outgoing port for the GPS to work - Mike |
Posted: Fri Jul 20, 2007 9:34 am Post subject: |
hi Mike
Thanks for the reply, flight is off, and I use the other Bluetooth option on TT5 it goes through Bluetooth port on serial com6 but still no joy will try again though
thanks
john |
Posted: Fri Jul 20, 2007 9:38 am Post subject: |
it seems like everytime I go into TT5 it stop the pairing of the devices. I go into TT5 then come out and look in Bluetooth manager and the active connection isn't there anymore |
alix776 Pocket GPS Moderator
Posted: Sat Jul 21, 2007 12:54 pm Post subject: |
try a hard reset then reinstall any programs you have again this is a last resort option make sure you sync the xda before hard reseting _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Wed Jul 25, 2007 5:50 pm Post subject: |
Right, finally sorted this out. Uninstalled Tom Tom Nav5 and then wiped the folders off the card. then put them on again from the Disc and re installed it. Then I opened the bluetooth manager paired the devices, and then opened TT5 and selected the GPS device as a "Wired other" and selected the Bluetooth serial port Com6 and it worked fine and has done since.
Thanks guys, got there in the end |
