Pocket GPS World :: View topic - POI on Nuvi 300 not showing after adding Safety cameras
NimbusII
PostPosted: Tue Jul 10, 2007 6:17 pm    Post subject: POI on Nuvi 300 not showing after adding Safety cameras Reply with quote
I have a Garmin Nuvi 300t, I have downloaded and installed POI using the poiloader software with no problems but when I install safety cameras using the poiloader the original POI dissapear. Is it possible to have POI and safety cameras installed at the same time and if so how?
NimbusII
PaulB2005
PostPosted: Tue Jul 10, 2007 6:24 pm    Post subject: Reply with quote
If these are other POIs (such as BP, Asda, Halfords etc) you downloaded you must put the other POIs in a folder with the speed cameras on your PC and upload the lot together.
POILoader wipes out all POIs before you install new ones.
PhilHornby
PostPosted: Tue Jul 10, 2007 8:52 pm    Post subject: Re: POI on Nuvi 300 not showing after adding Safety cameras Reply with quote
POI Loader always creates POI.GPI, but the Nüvi will access any '.GPI' file. So, you could rename your existing POI.GPI to (say) static.GPI; when you next run POI Loader (to load your safety cameras), it will create a new file, rather than overwriting the existing POI's.
22.052 (08 May 24)
