Pocket GPS World :: View topic - Mitac Camera database to cost Eu34
Sallyann
PostPosted: Fri Jun 08, 2007 3:46 pm    Post subject: Mitac Camera database to cost Eu34 Reply with quote
So Mitac have decided to start charging for camera updates, at 34 euros a year after the first year's free subscription.
It makes the PGPSW database look even better value!
Sal
Retty
PostPosted: Sun Jul 01, 2007 3:46 pm    Post subject: Re: Mitac Camera database to cost Eu34 Reply with quote
Sal
How so? With the exception of Germany and Austria, admittedly big exceptions, doesn't the Mitac database cover all mapped countries?
The PGPSW database, whilst better for UK mapping, is restricted to the UK isn't it?
PaulB2005
PostPosted: Sun Jul 01, 2007 4:00 pm    Post subject: Reply with quote
European, Australian / New Zealand, Africa, USA and Asia databases are now avalible. See http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=56726&highlight=
GPS_fan
PostPosted: Tue Jul 24, 2007 8:11 am    Post subject: Re: Mitac Camera database to cost Eu34 Reply with quote
Sal
At today's exchange rate, 34 Euros equates to about 22 pounds - roughly the equivalent to a year's subscription to PGPSW.
However, the Mio speed camera database is limited to updates by Mio users, whereas the PGPSW database is updated by users of a host of different GPS manufacturers' systems and sites are verified, unlike Mio which just adds all 'new cameras'.
The biggest problem with either database is that mobile cameras cannot be allocated a speed limit due to a restriction of the MioMap software (unless there's been an update that I 've missed which has fixed this).
Other systems, such as Snooper and Road Angel charge about 5pounds a month for their updates - so Mio and PGPSW databases are still relatively cheap.
Andy
PostPosted: Tue Jul 31, 2007 5:36 pm    Post subject: Reply with quote
I think that I will investigate patch_ui about speed limits for mobiles. I'm sure (without checking) that the MIO deliberately does not display speeds for mobiles, but am not certain what happens if the display limitation is taken off. If that does not work, I'll see if I can add the local speed limit to the Mobile cam display.
Trevor
Sallyann
PostPosted: Wed Aug 01, 2007 12:03 pm    Post subject: Reply with quote
Trevor,
I'm afraid you can't 'reveal' the speed of the mobile camera because it isn't included in the MTC file, and if it was the present version of MioMap is not capable of reading it.
If you are going to work on this I would suggest your second line might be more profitable - with the caveat that the maps are often out of date with regard to speed limits.
Good luck!
Sal
PostPosted: Wed Aug 01, 2007 5:43 pm    Post subject: Reply with quote
Sal,
Thanks for your reply and your PM on the same subject.
I have found a file definition for the spud??? file for the 310. I don't suppose you know off the top of your head whether this is the same as the .mtc file format (or indeed identical) They have an excel spreadsheet and do the manipulation in VBA so I'll be OK there then.
I suppose it's a bit dubious as to whether to alert at the local (possibly wrong) speed limit or just to leave things as they are. But as I'm always up for a challenge, I'm going to have a go anyway and then decide whether to use it or not.
Trev
Sallyann
PostPosted: Thu Aug 02, 2007 10:13 am    Post subject: Reply with quote
Trevor,
I understand that the spud format is only for the US versions. If so, then it is not compatible with the European MTC files.
Sal
PostPosted: Thu Aug 02, 2007 12:53 pm    Post subject: Reply with quote
Sal.
Of course, you're right. I loaded a .mtc file into the spreadsheet and came up with a load of gobbledegook. Oh Well!!!!
Trevor
22.054 (22 May 24)
