GPSinC3 Lifetime Member
Posted: Sat Jan 24, 2004 6:18 pm Post subject: External Antenna |
Can't get a reliable signal in car so have ordered ext antenna to connect through. Anyone any experience of this with BT GPS? |
Dave Frequent Visitor
Posted: Sat Jan 24, 2004 6:57 pm Post subject: |
It depends if your car has a UV coated windscreen or a heater coil running through it. UV screens will dampen GPS signals, some heater coils may cause problems in the windscreen but some are okay. |
Posted: Sun Feb 01, 2004 12:20 am Post subject: External Aerial |
Found position of GPS very critical in my car Citroen C3, not at all in front, acceptable sometimes on rear parcel shelf but sensitive, a 4 inch movement created 'GPS not found' very regularily
Have now installed external antenna, and seems to have done the job. Very pleased, very neat little black box with mag mount, wires easy to hide, and this allows GPS to stayat front so I can switch it on and off and recharge from cable off Loox. Now get 7 to 10 sats.
next job to try in different vehicles, won't take ext aerial off, but hope it will work. Trying in Spain in a Smart car. |
Darren Frequent Visitor
Posted: Sun Feb 01, 2004 9:54 am Post subject: |
This is due to PSA using the solar refelective coating on all their vehicles which effectively blocks the signal. You should however be able to receive a signal if the receiver is placed wither in the very bottom left or right of the screen or directly behind the interior mirror (where the block of black dots is printed on the glass).
I'm surprised that you had problems when placed on the rear parcel shelf as the rear screen is rarely coated but it could be the de-mister. At least with the external antenna you have covered all bases now so should be able to get a signal regardless of vehicle _________________ Darren Griffin |
