Newsletter
Pocket GPS World :: View topic - Nokia E61 Install help
wazzzzupmate
PostPosted: Tue Mar 06, 2007 5:01 pm    Post subject: Nokia E61 Install help Reply with quote
I installed tomtom 6 onto my Nokia E61 and it worked ok, but ran a bit slow. I thought I would un-install it and try again, and see if I got an option to install to phone memory. I removed the application, but now when I try to re-install it starts the process but fails with the message 'unable to install'
I have reset the phone to factory setting, and have tried a different SD card.
Any help please.
omnisvalidus
PostPosted: Thu May 31, 2007 10:49 am    Post subject: Reply with quote
I know this answer's a few months late but I just came across your post and as I had the same problem recently I thought I'd share my solution.
I assume you are trying to install using the Application Manager on the phone. This didn't work for me and I got the same message. The way I solved the problem was to run the TomTom install program directly. Open the File Manager application and point it at the TomTom memory card. Locate the .SIS file (there should only be 1). I used the find option to rather than looking through all the folders. Run the file and see if that works, it did for me.
20.081 (03 Aug 22)
