Pocket GPS World :: View topic - Frustration with 9559X
woofwoofx
PostPosted: Fri May 04, 2007 7:48 am    Post subject: Frustration with 9559X Reply with quote
Hello there,
Hope someone can put an end to my misery, I bought a Leadtek 9559X which worked for 30Sec where I was able to pair it to my SonyEricsson P990i it was possible to see the Sats and the compas was working fine. and while everything seemed like paradise the signal was lost and it has been 4 days now that I am not able to get the small mouse working.
Itried it with tomtom tried it with Mgmaps tried it with Winfast Navigator...
made a cold start...removed the battery....drained the battery then recharged it to max....left it outside a whole night..
Yet Nothing....
The situation is the following:
-BT...Steady blue light and connection paired with 0000
-GPS... blinking green as a normal situation
-Serila...using COM9 on PC and tried every single baud from 4800 to 38400 SiRF and NMEA
Please help...
PostPosted: Fri May 04, 2007 8:40 am    Post subject: Reply with quote
I would start by deleting the BlueTooth Bond for the GPS with your phone, then re-create this from scratch.
Don't mess around with SiRF mode, leave the device in NMEA mode that is the type of GPS data TomTom understands, feed it with SiRF and you get nothing - is it possible the device is now using SiRF mode? - if so switch it back, you should be using a Baud rate of 38400 (info taken from Here ) - Mike
woofwoofx
PostPosted: Fri May 04, 2007 1:20 pm    Post subject: Reply with quote
Thanks a million Mike,
I tried everything (i guess) yet nothing has come up, I talked to the leadtek support and we were trying to trouble shoot the issue also to no avail...
The connection is set perfectly but...no sat fix and no data.
Using Gmonitor11 and SiRFDemo but nothing is being seen except in ASCII and Binary mode.
Any Ideas are apreciated
Danny
22.044 (24 Apr 24)
