dosser Occasional Visitor
Posted: Sat Mar 31, 2007 4:26 pm Post subject: how many??? |
how many poi's will a tomtom 300 hold as i'm having problems with them disappearing at about the 70 mark, any info would be helpful Cheers lyndon |
Posted: Sat Mar 31, 2007 4:32 pm Post subject: |
It depends on the version of TomTom software you have installed,
Version 5 is 39 (with the exception of one specific version)
Version 6 is 100
The quantities are for the number of Custom POI Categories you have installed, look at your map folder via the PC and count up the number of files with the extension of .ov2
You might need to set Windows Explorer not to hide file extensions to see the ov2 part, go to Tools/ Options view tab make sure Hide extensions for Known file types is NOT selected, and while you are there make sure show hidden files IS selected - Mike |
Posted: Sat Mar 31, 2007 4:45 pm Post subject: |
the only version i can see is App v5.202 and GPs v1.21 does this mean anything to you..? |
alix776 Pocket GPS Moderator
Posted: Sat Mar 31, 2007 4:50 pm Post subject: |
it looks like you have version 5 so the maximun number or poi catagories that you can put on it is 39 the preinstalled ones count as on catagory _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
tonys66 Lifetime Member
Posted: Sat Mar 31, 2007 4:54 pm Post subject: |
39 on that mate need to update |
Posted: Sat Mar 31, 2007 5:04 pm Post subject: |
You notice I said earlier with ONE Exception - the exception is 5,202 which has a limit of 27, I suggest you update to a newer version, or even consider installing version 6 software to your device to realise the full 100 POI limit.
As always make sure you do a full back-up of the memory card to the PC BEFORE updating your software, that way you can always revert back if something goes wrong - Mike |
