chrisb80 Lifetime Member
Posted: Sun Mar 18, 2007 10:35 pm Post subject: NO CAMERA WARNINGS ON c510 |
Hi, I have a c510 with Garmin camera database. I downloaded pgps single zone cameras and in proximity points they are ticked as on. I also have the Garmin ticked. When I approach a camera I get a warning ,but only from the Garmin database. If I untick the Garmin I get no warning at all. Is there something else I should be doing? |
roadrunner69 Lifetime Member
Posted: Mon Mar 19, 2007 12:10 am Post subject: |
Hi Chrisb80
You need to install the camera db using poi loader in manual mode - not auto
this lets you set proximity distances and warning sounds.
hope this helps. |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Mon Mar 19, 2007 1:07 pm Post subject: |
roadrunner69 wrote: | You need to install the camera db using poi loader in manual mode - not auto |
The PocketGPSWorld files already contain speed/proximity information in a form that POI Loader recognises. Manual mode does not override information in the file. So if manual mode makes a difference, the wrong set has definitely been loaded in the first place.
Disappointing that no-one from Pocketgps world answered this query. Customer support? |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Mon Mar 19, 2007 1:29 pm Post subject: |
Firstly, try downloading the POI Loader version of the Garmin PGPSW camera database, and then install it via POI Loader using the Express Mode (but make sure it's set to Feet and MPH).
Then check that you can see the various camera files by going into Where To? Custom POIs (you may need to select another option before getting to this menu). You should then see the different camera files.
PhilHornby - they only got back from CeBIT late last night, and I think they have concentrated on questions in the dedicated subscribers area whilst away. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Mon Mar 19, 2007 3:06 pm Post subject: NO CAMERA WARNINGS ON c510 |
Thanks to all for your input ,will give your instructions a try shortly. |
Posted: Mon Mar 19, 2007 8:22 pm Post subject: NO CAMERA WARNINGS ON c510 |
Hi,I did exactly what Swing advised when I downloaded originally. Yes if I go into -where to-Custom poi's- it gives 3 options 1-all categories 2--pocketgps-uk-sc 3--pocketgps-uk-pmobile. If I touch any of these it shows me cameras in a radius of up to 10 to 30 miles. If I click on one I then get a screen that says GO. and if I touch on that it presumably takes me to that location, but as far as I can see there are no other options. |
Posted: Mon Mar 19, 2007 9:06 pm Post subject: Re: NO CAMERA WARNINGS ON c510 |
chrisb80 wrote: | If I click on one I then get a screen that says GO. | That screen should also show "Alert Information:" with a distance and speed. If it doesn't , then I reckon you've loaded the wrong set of files (easily done, it has to be said).
Check this http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=51761 -- that's what had happened here. |
Posted: Mon Mar 19, 2007 10:18 pm Post subject: NO CAMERA WARNINGS ON c510 |
Hi Phil,yes the screen did show "alert information" etc. I looked at the link you sent, but still can't understand what is meant by loading wrong set of files, I thought you just chose between "single file" or"speed zoned etc. Anyway I always intended loading speed zoned along with some other pois. to replace the single zone, and already had them in a folder on desktop, so I have now done that and have literally got dozens of categories showing. I assume the only way to set them as on is by ticking the box on Custom POIs in the proximity alerts screen? I'll give it a try next time I go out and report back, thanks Chris. |
Posted: Mon Mar 19, 2007 10:57 pm Post subject: Re: NO CAMERA WARNINGS ON c510 |
chrisb80 wrote: | Hi Phil,yes the screen did show "alert information" etc. | Good - so you're up and running then. Quote: | I looked at the link you sent, but still can't understand what is meant by loading wrong set of files | There's a set lurking in there with no speed or proximity information - meant as an overlay for some other GPS? Quote: | I assume the only way to set them as on is by ticking the box on Custom POIs in the proximity alerts screen? | Correct. Quote: | I'll give it a try next time I go out | You can test them, using the "simulate driving this route" function.
Press 'spanner'
system
GPS Mode=OFF
Where to?
Extras
Custom POI
Pick a camera and hit Map
tap somewhere down the road from the camera and
Set Loc.
Hit Back
Hit GO (i.e. drive to your selected camera)
Do you want to simulate driving this route? -- say yes.
Posted: Mon Mar 19, 2007 11:17 pm Post subject: NO CAMERA WARNINGS ON c510 |
Hi Phil, just drove simulated route and the cameras appeared ok. Will try it tomorrow and see if it's ok live. Great tuition , thanks Chris. |
Posted: Sat Mar 24, 2007 7:49 pm Post subject: DOWNLOAD TO GARMIN c510 |
Hi again, I've now tried out the detector locally and on some cameras I now get a warning bleep with red info, but some give no sound and only show the image of a camera on the road, and nothing else. Is this how it should work with different camera types, or have I got to enter something else. Also if I want to download any other pois am I correct in assuming that, every time,I have to put these in the folder on my desktop containing my original camera database and existing pois, and then download the whole lot again, as I believe every time I download any pois it deletes any already loaded. thanks for any info, it might sink in one day. |
Posted: Sat Mar 24, 2007 8:40 pm Post subject: Re: DOWNLOAD TO GARMIN c510 |
chrisb80 wrote: | on some cameras I now get a warning bleep with red info, but some give no sound ... have I got to enter something else. | I think you're possible going too slow to trigger the alert
Actually, until April 17th I'm running Garmin's own camera database (that's when the trial runs out) - I thought I noticed a change in behaviour with the last firmware upgrade (v5.4.0), but assumed if I had, it was a Garmin-database only thing. Maybe not?
Quote: | ...I have to put these in the folder ...containing my original camera database and existing pois, and download the whole lot again |
POI Loader's output is a single file called POI.GPI. It overwrites the existing one, so the simple answer to your question is "yes".
That's probably the way most people do it. However, I like to be able to alter the order that things appear in the list, (without calling them AA_McDonalds and ZZ_speedcameras;-) - so I use separate .GPI files.
I run POILoader against the directory in question and then rename POI.GPI to something meaningful (like Petrol Stations.gpi) for example, and keep these files separate. You can reserve the un-renamed POI.GPI for data that's changing frequently - such as your speed cameras.
Actually, I get POI LOader to write to an SD card and then put that in the C510.
It will say "Do you want to copy this data?" when it spots new files. You can either say "No", in which case it will ask every boot, or say "yes", click [x]Don't ask me again, followed by "skip this file" - in which case it will never ask again and access them in situ.
What I do, is skip through to the one I want first, and say "Yes", pop the card in and out and skip through to the next one and say "yes", until they're all done. Once the order is set, you don't need to keep setting it in future.
Far too time-consuming and fiddly for most people - but I like it |
Posted: Sat Mar 24, 2007 9:30 pm Post subject: DOWNLOAD TO GARMIN c510 |
Thanks for prompt reply Phil. with all the detail. I did wonder about the speed a couple of times, but this morning I was doing 65 approaching where I know there is occasionally a mobile,and it only showed an image on the map.cheers Chris I have the Garmin database and started the 90 day trial a couple of weeks back,but have unticked it to try the pgps download. In fact a couple of miles from mine the Garmin will alert to a mobile, and the pgps doesn't. Anyway I'm on a journey to the airport tonight, and I know there are a lot of cameras on route so I'll see what shows up. As to your way of setting pois ,I haven't yet got an SD card and I'm not quite confident enough or proficient yet to really get into it , but I'll keep a copy for the future. As to this Garmin trial does the database finish at 90 days or does it just continue without being able to update unless I subscribe,cheers Chris |
Posted: Sat Mar 24, 2007 10:00 pm Post subject: Re: DOWNLOAD TO GARMIN c510 |
chrisb80 wrote: | As to this Garmin trial does the database finish at 90 days or does it just continue without being able to update unless I subscribe |
Dunno - ask me on April 17th :D |
Posted: Mon Mar 26, 2007 10:05 pm Post subject: NO CAMERA WARNINGS ON c510 |
Hi, during my recent journey it appears that my camera warnings are working. So thanks to Phil and others who replied. Phil was correct in pointing out that the bleep alert sounds only when you are going overspeed on approach. |
