chippy24 Occasional Visitor
Posted: Fri Jan 09, 2009 4:12 pm Post subject: POI's onto pna250 |
Hi How do I put the pocket gps POI's onto the map SD card and how do I unzip them to use on tomtom navigater 5 mobile |
philpugh Lifetime Member
Posted: Fri Jan 09, 2009 5:06 pm Post subject: |
There's a detailed guide to be found here
All you need to do is unzip the file and put the files into the particular map directory you are using. The name of this directory varies depending on which map you are using and which version sometimes.
If you have multiple map directories they need to be placed into each one. _________________ Phil |
Posted: Thu Jan 15, 2009 11:41 pm Post subject: Unzipping POI's |
What program do you use to unzip the poi's? I'm new to doing this, so I am not sure how to unzip |
Andy_P Pocket GPS Moderator
Posted: Fri Jan 16, 2009 12:33 am Post subject: |
If you are using Windows XP or Vista on your PC, you don't need any extra programs.
Just right-click on the zip archive and select "extract all" from the drop-down menu.
If you are using a Mac, then I think "Stuffit Expander" is liked.... |
Posted: Fri Jan 16, 2009 10:14 am Post subject: extracting files |
Cheers for the info on how to extract the poi files, I can now give it a go . thanks |
