Pocket GPS World :: View topic - MM V5.0.0 build 608 Crashes
gorstj
PostPosted: Mon May 07, 2007 10:25 am    Post subject: MM V5.0.0 build 608 Crashes Reply with quote
I was wondering if any of you fellow MM users have experienced this, and hopefully found a solution.
I have MM version 5.0.0 build 608 on my PDA. Every time I power down the device with MM running, when I switch it on again it usually spontaneously exits Sad
This is not very good as I loose all the info on the screen, e.g. tracking data, since I last exit the applicaiton.
I am running on a Dell axim X50v from a sandisk compact flash card. Os is WM5. GPS is from a bluetooth BT 338
Thanks for any help.
MrT
PostPosted: Tue May 08, 2007 12:31 pm    Post subject: Reply with quote
I have not come across 5.0.0, but try the latest version which you can download through the Memory Map menu on "Web" then "check for updates...." If you cannot get that far before crashing just go to the web site http://www.memory-map.co.uk/dl_mm_OS_V5.htm
philpugh
PostPosted: Wed Jun 06, 2007 2:11 pm    Post subject: Re: MM V5.0.0 build 608 Crashes Reply with quote
[quote="gorstj"]Hi
quote]
Sorry to resurrect old note - but only just noticed it.
You need to exit the application before swtching off - if you don't the BT comms gets corrupted and the application will hang or crash or you can lock-up the PDA. It happens with TomTom also.
Phil
