Pocket GPS World :: View topic - 3800/ Copilot 4 Jacket problem
x29c
PostPosted: Wed Dec 31, 2003 5:05 pm    Post subject: 3800/ Copilot 4 Jacket problem Reply with quote
Got my new Copilot Pocket PC4 in 2 days ago and cannot get it to work properly. I tried the US numbers and their customer support and got no response. Hopefully you can help me out with this setup problem.
I am getting no GPS signal. I am using com port 1, 4800 baud and have a check on receiving under the GPS tab. GPS status page has a check by the GPS Com port opened and stops at detecting GPS signal.
I have tried reloading the software and re-racking the sleeve many time without any luck.
I have tried com port 5 as the Emtac page says for the 3800 series iPaq and do not get the com port opened message on the GPS status page.
On the GPS options page when I do an Auto Scan it does not find the com port.
Under System Setting- Expansion Pack Information, it gives a Description of Copilot GPS Jacket.
Do I need to install drivers for the GPS jacket? Installing CP4.5 over CP3.0 seems to have solved this problem for others in the Forums but I do not have a copy of this.
I am using:
iPaq model 3835 with Pocket PC Version 3.0.11171
Copilot Live version 4.5 with Packet PC Jacket
Any help will be greatly appreciated.
Thank you :|
PostPosted: Thu Jan 01, 2004 1:08 am    Post subject: Reply with quote
Try using a GPS diagnostics program (like the Emtac CruxView) . I have the CoPilot iPAQ jacket as well, but on my iPAQ 3970 it installs at COM4 - you may want to try that.
No additional driver is required - the jacket behaves as a standard modem., sending out the NMEA stream.
x29c
PostPosted: Thu Jan 01, 2004 4:44 am    Post subject: Reply with quote
I did get in touch with an ALK Rep. from the UK. She told me I have a defective sleeve. It will be another month before I will get to try it out again. They are sending me a mailer box. I send it back and then they will send me a new one. Sad
