Newsletter
Pocket GPS World :: View topic - Destinayor 6 - GPS Problem
Petersirish007
PostPosted: Sun Jan 14, 2007 1:12 am    Post subject: Destinayor 6 - GPS Problem Reply with quote
Hi Guys
I need your help and know it's only here I will get it.
I have just purchased HP iPAQ2795 in the USA after my old HPiPAQ4350 was not compatable (Windows 2003) to use with the Destinator 6 (so I was told by the nice people in Germany)
I have loaded the software (Destinator 6) and everything was fine and and the external aerial fitted perfectly ( which I hadnt planned)
So what's the problem you ask?
Well when I go looking for the GPS after setting the folloeing:
Com1 - Baud 4800 Protocol NMEA it tells me its sees the External Aerial and then when I say Done - I get the message cannot connect to GPS.
On the main menu if says GPS not Found.
I have gone into the connections and turned off the "Beam" as per the instuctions from the Support people in germany.
Is my problem the the Destinator Aerial is not compatable?
I have purchased a Bluetooth GPS Aerial from ebay and hopefully it will work.
Any Ideas guys?
Would appreciate your help as I use the Destinator system for work and my boss will get pi**ed off with me when I cannot find clients addresses.
peter
allmen
PostPosted: Mon Jan 29, 2007 3:24 pm    Post subject: Reply with quote
I had an Acer N35 PDA/GPS with a similar problem and discovered it was the main board that had developed a fault, outwith the guarantee of course:).
Perhaps if you contacted the people on this web site they may help you better than I could. They did fix my problem and it wasn't even an iPaq
iPaq repairs
Acer N35
Destinator 3
Destinator 6
20.082 (10 Aug 22)
