Pocket GPS World :: View topic - GPS Receiver question
NigelO
PostPosted: Wed Nov 22, 2006 9:45 pm    Post subject: GPS Receiver question Reply with quote
My CoPilot Live came witha CoPilot branded BT GPS receiver.
I've recently tried (and failed) to run another GPS application
Copilot finds a fix, but as soon as I switch to the alternate application, it reports no GPS hardware.
Is the branded receiver "locked" in some way to only provide GPS data to the CoPilot application?
johnbarnes
PostPosted: Thu Nov 23, 2006 5:15 pm    Post subject: Reply with quote
If you want to feed the GPS data stream to more than one application at a time, you need the GPSGate utility, or something equivalent.
CoPilot Live 7, Fugawi Global Navigator, Pocket Streets, iPAQ 5550, GlobalSat BT338 GPS, Brodit Powered PDA mount, Jabra BT250 headset.
terp
PostPosted: Tue Feb 06, 2007 12:18 am    Post subject: Reply with quote
What if you want more than one application to access the GPS unit, but only one at a time.
For example, the new Google Maps application for WM5. I'd like to be able to use my CoPilot BT GPS with this app. How can I do this?
I have a Treo 700w (WM5) with CP Live 6 installed. I purchased this with
the CP branded BT GPS unit (BTGPS3 / D1598-S).
It works great.
Com settings I need help with:
Start / Setting / System / GPS / Programs / GPS program port:
Start / Setting / System / GPS / Hardware / GPS hardware port & Baud rate:
Start / Setting / System / GPS / Access / Manage GPS automatically
(checked or not checked?)
22.044 (24 Apr 24)
