Pocket GPS World :: View topic - COMPLETELY resetting Tom Tom Go
Janice
PostPosted: Thu Jan 04, 2007 11:32 am    Post subject: COMPLETELY resetting Tom Tom Go Reply with quote
How do I COMPLETELY reset the Tom Tom Go to how it was when it left the factory. I have tried dooing it from the cd but it doesnt correct the problem. I am getting no satellite signals...even standing out in the garden, and if I finally do get a signal..after a while the menu flicks up.. then off again... its all over the place. Sad
Janice
PostPosted: Thu Jan 04, 2007 11:43 am    Post subject: Reply with quote
Hmmm now there is no power on at all. i have tried the paperclip reset option. Now when i press the on button the screen has a slight something on its top half but thats all..just a stripey pattern. does the same when plugged into the car.
Is it f******d?????
PostPosted: Thu Jan 04, 2007 11:55 am    Post subject: Reply with quote
Try pressing and holding the reset button in for 30 seconds then see if it will power up - Mike
Janice
PostPosted: Thu Jan 04, 2007 12:06 pm    Post subject: Reply with quote
Are you clever or what???? :D :D :D
Now ive just got to work out why no satellite signal and the menus are jumping on and off on their own!! Confused
philip4242
PostPosted: Sat Jan 06, 2007 12:17 am    Post subject: Reply with quote
Just a couple of ideas, Janice.
Now that you've factory reset the GO, it'll probably take at least 20 minutes of being in a good reception area to re-acquire all the satellites, before it shows your current location.
Also, can I suggest that the menus coming and going might possibly be the removable bezel round the screen pressing onto the screen, possibly by something being wedged under the bezel ?
If you follow the instructions to remove the bezel, then power-up, it should be obvious if that problem has been solved; then carefully clean and replace the bezel.
Getting older and more senile by the minute !
Philip
22.051 (01 May 24)
