Pocket GPS World :: View topic - new voices
new voices
rejo
PostPosted: Mon Jan 01, 2007 2:39 pm    Post subject: new voices Reply with quote
Can anyone help me. Just bought a nuvi 350 and really pleased with it, was a toss up between the tt one and the nuvi. The only thing I dont like about it is the voices, there almost scary and very electronic sounding compared to other navigation units. Is it possible to change these voices or add others which are more friendly sounding and if so where can I get them from. Any other tips or tricks that can be used on the nuvi that might be of interest to me ...........
motocareltd
PostPosted: Thu Jan 04, 2007 11:07 am    Post subject: Reply with quote
was after knowing this myself...
anyone any ideas...????
Abakus
PostPosted: Fri Jan 05, 2007 5:39 pm    Post subject: Soundfiles Reply with quote
hm - there might be no new voice at moment except one new german one, but tools to split and merge a garmin vpm files are avaliable now.
Eldar
PostPosted: Fri Jan 05, 2007 10:13 pm    Post subject: Re: Soundfiles Reply with quote
Abakus wrote:
.... tools to split and merge a garmin vpm files are avaliable now.
where from?
Ash10
PostPosted: Sat Jan 06, 2007 8:17 pm    Post subject: Re: Soundfiles Reply with quote
Eldar wrote:
where from?
I've had tools available for the last year or so - see link below...
Eldar
PostPosted: Sat Jan 06, 2007 10:44 pm    Post subject: Re: Soundfiles Reply with quote
Abakus said that he "made a tool which should split and merge VPM file of any language with correct pointer tables"
"any language" is the key for me here.
BTW, does your tool work on Nuvi voices?
Abakus
PostPosted: Mon Jan 08, 2007 10:10 am    Post subject: Reply with quote
Yes, as far as i Know my tool works for any languange and seems to have almost no limitations about chnaging the wav sound snippets.
If it works for Nuvi 330 - i am not sure. If you can get the ***__.vpm out of the Nuvi and store it back onto it via USB you are (most probably) all set - thats what my tool works on.
It splits the VPM down to the tables, provides the Wavs, and can reconstruct the VPM out of the original table snippet and the (possibly modified) Wavs.
I have followed the work from Ash10, but i have provided complete reconstruction of the Wav tables.
btw, Ash was right about the IMD 4 bit mono wav mode - but there is another wav type in the VPM allowed - its PCM 16 bit mono, and i have tested it and it works. (these files are 4 times longer than IMA).
The only thing is - program and descriptin are mostly in German at moment - i would only like to change it if there is significant interest.....
Abakus
PostPosted: Mon Jan 08, 2007 10:13 am    Post subject: Reply with quote
Addition - my tool can as well read the *.RGN files - which can be extracted out of any (voiceupdate).exe by unzipping the exe (yes, that works, it gives an Updater.exe and the *.RGN).
Eldar
PostPosted: Mon Jan 08, 2007 10:20 am    Post subject: Reply with quote
I''d certainly be interested to see it.
Abakus
PostPosted: Mon Jan 08, 2007 11:07 am    Post subject: Reply with quote
http://www.pocketnavigation.de/board/tid1055743-sid.htm
last post
Eldar
PostPosted: Mon Jan 08, 2007 11:33 am    Post subject: Reply with quote
Abakus wrote:
last post
you were right, it is in German ;-)
