Pocket GPS World :: View topic - Garmin C510D info please
chajun
PostPosted: Mon Jan 22, 2007 3:04 pm    Post subject: Garmin C510D info please Reply with quote
I am a bit confused to know if the traffic system is working correctly. If I touch the "car symbol" I get lot's of triangles showing different road designators with different colours. are these supposed to be superimposed on the route map to display problems enroute or ? Does the WAAS setting play any part in this or not. If not when should it be used?
Thank you
chajun
PostPosted: Tue Jan 23, 2007 12:28 pm    Post subject: Garmin C510D info please Reply with quote
Any help appreciated.
Thank you
philpugh
PostPosted: Tue Jan 23, 2007 3:20 pm    Post subject: Reply with quote
You may want to post this in the GARMIN navigation forum on this site - or better still could a Moderator move this topic?
portman
PostPosted: Tue Jan 23, 2007 9:41 pm    Post subject: Reply with quote
WAAS is an american system to give the GPS better accuracy, not related to the traffic.
As far as the traffic goes, when you have the two white cars(as opposed to greyed out) on the main menu it means you have traffic info. if no traffic signal is received the 2 cars will eventually turn grey, this doesn't happen immediately you lose the signal because much of the traffic info it valid for long periods, e.g roadworks.
To check if you are receiving a traffic signal the LED on the power lead will show green, if it is searching for a signal it is amber. The other LED on the power lead is used to indicate power to the unit.
The traffic list shows the received traffic, if you click on one of them it gives more info and by pressing the map button it will show you where is affected. The traffic will also show on the main map screen. and if whilst you are being directed a traffic event happens on your route a red triangle will appear on the right hand side, press it and follow the info.
Samsung Mega
Tomtom 500
chajun
PostPosted: Tue Jan 23, 2007 10:18 pm    Post subject: Garmin C510D info please Reply with quote
Thanks for that.
22.052 (08 May 24)
