Pocket GPS World :: View topic - Can't install Voices on TTN6
keithmillar
PostPosted: Sat Dec 16, 2006 3:33 pm    Post subject: Can't install Voices on TTN6 Reply with quote
Hello,
I've just bought TT6, and installed it onto my PDA, but i can't get the voices to work, the folder called "Voices" on the SD card is empty, but i can't drag and drop and i'm being told i don't have permission to do it.
Also, where i can i turn the POI noises for the speed cameras into voices as well.
Thoughts, comments advice, please
Regards
Keith
PostPosted: Sat Dec 16, 2006 4:05 pm    Post subject: Reply with quote
Keith, Are you using the TomTom Home application to transfer the voice files? try using Home, also check your memory card write protection switch isn't in the locked position.
For spoken alerts I suggest you have a read through a few posts in THIS Thread, its quite easy to do - you don't need to read much past the first post to get the instructions to be honest - Mike
keithmillar
PostPosted: Sat Dec 16, 2006 4:24 pm    Post subject: Reply with quote
Hi Mike,
I'm using TomTom Home, i have a list of named voices on the screen, but first time i tried to select the voice i want, the screen prompt said incert disc? and now the prompt says i'm trying to install a volume that is read only.
Is the locked switch on the side of the sd card, if so then i've tried this in the up and then down postion and got nowhere
Keith
PostPosted: Sat Dec 16, 2006 4:35 pm    Post subject: Reply with quote
Are you installing a download or TTN6 from DVD?
The lock switch is the small switch on the side of the card to be in the read/ write position hold the card with the gold contacts at the top, chamfered corner top right, the switch is on the left and needs to be in the UP position - Mike
keithmillar
PostPosted: Sat Dec 16, 2006 4:41 pm    Post subject: Reply with quote
I have the TTN6 software on the TTlogo sd card, and using the TT Home loaded from the cd that came with everything this morning.
Got the lock switch sorted, and tried to copy/paste 3 files over but still got nowhere, being told not enough memory/don't have permission.
Any ideas?
Keith
