Pocket GPS World :: View topic - SD Cards - what's the difference?
Faust
PostPosted: Sat Dec 09, 2006 11:20 pm    Post subject: SD Cards - what's the difference? Reply with quote
Can anyone explain what the differences are in the myriad of SD cards on the market - not the file size but the differences in types e.g. Ultra II, Extreme etc. etc. and which is best suited to SatNav devices.
PostPosted: Sat Dec 09, 2006 11:39 pm    Post subject: Reply with quote
Generally the Ultra, Extreme, High Speed, means it's capable of that bit extra speed in read/write operations.
My current one is classed as x80. A lot of people get x133. It reduces just one of the bottlenecks in the Data chain, and hopefully gives less problems, in our case, with PND's.
Border_Collie
PostPosted: Sun Dec 10, 2006 1:53 pm    Post subject: Reply with quote
Look in the specifications of your device to see the fastest speed it can read and write and match that.
The x80 and x133 ratings are a bit confusing as the actual read write speed on the x80 is around 10x and on the x133 about 16x.
If you have a device capable of read/write at x133 and you use a 4x read/write card, the card will slow things down slightly. If however you use a faster card than the x133, usually more expensive, you've paid for something which your device can't take full advantage of. Having said that, you may later upgrade your device to one which is capable of a faster read/write, in which case there is no harm done. Except of course, by the time you upgrade your device the faster card will have probably come down in price as faster ones are produced.
I found a big difference when changing from a standard Kingston card, 4x read/write, to their Ultimate x133. e.g. Installing maps via a card reader 'whizzed' through. Less lag on screen and voices, especially the final 'turn left/right', came in advance of the turn rather than at it with the slower card.
bazzza
PostPosted: Sun Dec 10, 2006 4:08 pm    Post subject: Reply with quote
Lost_property,
Do you know what the speed is of the originally installed sd card in TT Go 300. I have just bought a Standard Kingston 1.0 GB SD Card prior to getting the latest WE maps. Would I be better putting that down to experience and buying a faster card?
It seems to me that if the new maps have speed limits etc on them the card has a bit more to do.
Bazzza
bazzza
PostPosted: Sun Dec 10, 2006 4:13 pm    Post subject: Reply with quote
Sorry, couldn't edit. I also wanted to ask where I can get info on formatting a new SD Card?
Bazzza
PostPosted: Sun Dec 10, 2006 5:33 pm    Post subject: Reply with quote
You shouldn't need to Format a new SD Card.
But if you want to, just Right Click the Card when in Explorer and Select Format.
trog100
PostPosted: Sun Dec 10, 2006 5:58 pm    Post subject: Reply with quote
i did some speed read/write tests on a bunch of cards..
from the slowest to the fastet they vary by a factor of say four.. u cant reply on the so called speed factor either
the 1 gig card the newer western europe totmtom map comes on is pretty fast.. it compares well with a sandisk ultra 11 extreme..
however the 128 card that came with my go 300 is so slow its off the planet..
the fast tomtom 1 gig card now lives in my digital dslr camera.. tomtom has a generic cheapo 1 gig card in him and dosnt notice the difference..
basically a cheapo generic is plenty good enough for a tomtom..
trog
bazzza
PostPosted: Sun Dec 10, 2006 6:45 pm    Post subject: Reply with quote
Thanks Oldboy and Trog, That clarifies it for me.
Bazzza
mikeyking
PostPosted: Fri Dec 22, 2006 8:48 pm    Post subject: Reply with quote
Just got one of these for the TomTom One and it works perfectly. Really really quick and probably overkill for the device but it was cheap especially with the free P&P. I'm in no way connected to this company - all I can say is that I ordered it yesterday and received it in the post today...
http://www.valueshop.co.uk/info.asp?MFGno=SDCFX3-1024-902
Mike
mikeyking
PostPosted: Fri Dec 22, 2006 8:56 pm    Post subject: Reply with quote
Doh, top first post Smile The link is actually:
http://www.valueshop.co.uk/info.asp?MFGno=SDSDX3-1024-902
Mike
shauneco
PostPosted: Fri Dec 22, 2006 8:59 pm    Post subject: Reply with quote
Mike
That link is to a Compact Flash card, I very much dought that'll work in a TomTom as they use SD Cards!, I guess you posted the wrong link
mikeyking
PostPosted: Fri Dec 22, 2006 10:46 pm    Post subject: Reply with quote
mikeyking wrote:
Doh, top first post The link is actually:
rugrat2
PostPosted: Sat Dec 23, 2006 10:20 am    Post subject: Reply with quote
Its not so much the speed of the card,it is actually the make,they dont all work in a tomtom unit,I use Dane/Elect as they always work... :D
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
trog100
PostPosted: Sat Dec 23, 2006 3:21 pm    Post subject: Reply with quote
standard sd cards are pretty generic devices.. they should all work.. it is possible to have the odd faulty one thow..
trog
22.051 (01 May 24)
