Pocket GPS World :: View topic - Liz Whittakers speed camera warnings
Goto page 1, 2, 3  Next
Fat_Al
PostPosted: Wed Dec 06, 2006 9:17 pm    Post subject: Liz Whittakers speed camera warnings Reply with quote
Having just installed the new map update I no longer have liz Whittakers voice for the camera warnings ( tomtom would not boot with previous Data.chk file).
Is there is no updated data.chk file I will make my own .ogg files for the cameras using liz's existing warnings, but which file are they in?
Confused.... 8O
thebinman
Banned
PostPosted: Wed Dec 06, 2006 9:24 pm    Post subject: Reply with quote
http://www.tomtomsatnav.info/voiceskins.html
should be in your voices folder
Fat_Al
PostPosted: Wed Dec 06, 2006 9:28 pm    Post subject: Reply with quote
That's what I thought: When I load that data.chk file into my sound editor it shows only the direction instructions - no camera warnings, they SHOULD be in there???
thebinman
Banned
PostPosted: Wed Dec 06, 2006 9:36 pm    Post subject: Reply with quote
Sorry, try here; http://www.tomtomsatnav.info/realvoice.html
Fat_Al
PostPosted: Wed Dec 06, 2006 9:37 pm    Post subject: Reply with quote
OK panic over the file is at the bottom of this page
sgould
PostPosted: Wed Dec 06, 2006 10:42 pm    Post subject: Reply with quote
If you add the .ogg files (suitably renamed) that are right at the bottom of that page, to the map folder, you won't need to worry about the data.chk file again!
Map folder speed cam files should have three identical files if you do it this way. For example:
gatso_60.ov2
gatso_60.ogg
Reset the "Warn when near" distances (you won't be asked to select the sound, because it's now linked) and away you go!
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Simbo_Wales
PostPosted: Thu Dec 07, 2006 1:21 am    Post subject: Reply with quote
Which files do I need for the complete Liz Whittaker voice set (directions and warnings) for a TT700 with software version 6.150 and map Western Europe v660.1219 please?
PostPosted: Thu Dec 07, 2006 7:49 am    Post subject: Reply with quote
The Links for both the Navigation Voice AND the Warning Files are given above.;)
Simbo_Wales
PostPosted: Thu Dec 07, 2006 2:12 pm    Post subject: Reply with quote
Where does the bitmap image go on my TT? I have a voices folder but no skins folder.In the voices folder I have placed the data chk and the vif files but I cant select her!
Help please! Question
sgould
PostPosted: Thu Dec 07, 2006 4:02 pm    Post subject: Reply with quote
If you are replacing the data.chk file, you have the warning voices installed there. You don't use the Voices folder for the warning sounds. Voices folder is for the instruction voices - the numbered data**.chk files and matching .vif files.
The .bmp file should go in the map folder along with the .ov2 file of exactly the same name.
TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Shiftcontrol
PostPosted: Thu Dec 07, 2006 6:34 pm    Post subject: Reply with quote
My TTGo510 is running 6.52 with GPSW speed cameras.Have downloaded & installed Liz Whittaker OGG files under Maps.So have OV2.BMP,&OGG files for each camera however still get the old warnings.From recent posts it looks like you don't need to update data.chk file.
Help please
henryg
PostPosted: Thu Dec 07, 2006 7:10 pm    Post subject: Reply with quote
Shiftcontrol wrote:
My TTGo510 is running 6.52 with GPSW speed cameras.Have downloaded & installed Liz Whittaker OGG files under Maps.So have OV2.BMP,&OGG files for each camera however still get the old warnings.From recent posts it looks like you don't need to update data.chk file.Help please
Couple of thoughts:
Are the names of the ogg files identical to those of the speed camera ov2 files?
Have you reinstated the 'vanilla' data.chk file that is installed by TT6.52?
Henry
PostPosted: Thu Dec 07, 2006 7:52 pm    Post subject: Reply with quote
..... and have you gone into Warn When Near to setup the new ogg Files?;)
Shiftcontrol
PostPosted: Thu Dec 07, 2006 9:43 pm    Post subject: Reply with quote
henryg,
Your a star.
Just renamed the OGG file to pocketgps_uk_gatso_30.ogg & it works.
Nowhere I have read that you need to rename files
henryg
PostPosted: Thu Dec 07, 2006 10:58 pm    Post subject: Reply with quote
On a sort of connected topic, does anyone have the Liz or Vicki voices named for the speed cameras but without the siren that has been added at the beginning. OR the ones as above, but with oggs for 20mph cameras?
Henry
Page 1 of 3
22.051 (01 May 24)
